The Return to Steam
Started by markdansie, September 22, 2013, 04:35:21 AM
TS:
Can you show your link or links for the hydrosonic pump?
Thanks,
tak22
Richard Aho - Impact Steam Generator
http://www.rexresearch.com/ahomist/ahomist.htm
Quote"...Secondly, our steam is not generated directly from an external heat source; rather it is produced by hyper-sonic high impact molecular collisions which take place in our impact chambers which are located at the point of energy need.  This method of producing super-heated dry steam eliminates both the energy needed for the boiling of the water and the energy lost during the transportation of the steam.
I looked at the impact steam generator and sorry but I don't buy it.  I checked out the web site but didn't dig too deep because I had seen enough.
QuoteThe technology behind our system is simple. It is well known that both hydraulic power and its effect on fluid are both linear.  For example, if you increase the power by a factor of three, your output and expense will increase by a factor of three. However, since kinetic energy is exponential, the energy derived from the speed of the water molecules in this example will increase by a factor of eight.  Simple physics, abundant supply, and proven tests - Molecular Impact Steam Technology.
The idea expressed here is that since kinetic energy is proportional to the square of the velocity, that you are getting something for free.  The simple physics says no, so this has a show stopper problem from the start.
QuoteThe energy we must apply in order for our 10 HP pump to produce the required pressure to process 120 lbs. of water per hour is  7.46 Kw which is 124.3 watts per minute to pump 2 lbs. 0f water at 30,000 psi and a velocity of 3,000 m/s.  This gives us and output of 1139 watts using only 124.3 watts of energy.  The rest of the energy comes from the energy contained within the bonding of the molecules of water.
Another red flag, incorrectly expressing power and energy concepts.  It's inexcusable.  Let's suppose that he means 7.46 kWh of energy.  So that's 7460 x 3600 = 26.865 megajoules of energy.  That's 7460 joules of energy per second and 447600 joules per minute.  What the hell does he even mean when he says, "124.3 watts per minute?"  The assumption is that the rate of power consumption is 7.56 kW.
QuoteWe are not trying to say we are creating energy out of nothing. What we are doing is capturing the release of the energy holding the molecules of water together
Really?  It's more like you have to do mechanical work to pull the water molecules apart.  You have to put energy in to pull the molecules of water apart and you have to put more energy in to get the water molecules moving at speed.  It's almost like pulling magnets apart.  You are injecting energy into your system when you do that.
He is trying to suggest that when the water droplets slam into the target at 1700 meters per second that there is some kind of spontaneous extra energy release from the water molecules.  No way, when the water molecules hit the target the kinetic energy mostly goes into the water and it effectively boils.  This is just the kinetic energy in the water becoming the kinetic energy in the steam in one very short instant of time.  There is no reason to expect anything but normal physics and thermodynamics to come into play here.  You have some big electrical motor running some kind of special high pressure pump going through piezo-electric valves that let the water out in high speed droplets.  You have to think of the high pressure water just like being a wire at very high voltage.  Even a small flow of water at very high pressure represents a lot of power that has to go somewhere if you use it.  It's the same as high voltage, you know that just a little bit of current going into a high-ohmage resistor will make it hot because the power is proportional to the square of the voltage.  It's the same identical thing for the high pressure water.  The power you can extract from the water by having it flow is proportional to the square of the water pressure.
This Richard Aho impact steam generator is a device that obeys the conservation of energy, for sure.  At least that's what I'm seeing.
TechStuf
http://www.youtube.com/watch?v=yh_-DUKQ4Uw&list=PL5733824E8EC41CDA
http://www.youtube.com/watch?v=oha0Doj-seI&list=PL5733824E8EC41CDA
http://hydrodynamics.com/
Sono-luminescence has long held promise.  That it is being done mechanically, instead of solid state does not imply inefficiency.  Pistol Shrimp have been doing it long before man.
The technology appears quite valid to me....and apparently, Hydrodynamics' customers.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
TS:
That fuelless heater in the fire station clip is probably a good 10 years old by now.  It's almost the same principle.  He pumps big time mechanical energy into a drum from a motor shaft.  Inside the drum the water is being sheared by the moving parts and that mechanical torque x angular velocity input power simply has to go somewhere when it is pumped into the drum.  It becomes hot water, it's more or less the only place for the mechanical power to go.  So hot water literally has to come out of the drum.  The usual suspect problem is here in this clip, there are no power input vs. power output measurements, it's all anecdotal.  But the firemen are happy that's for sure!
Good for that company in finding industrial uses for cavitation.  There are lots of fascinating industrial processes if you are the type to like to watch buildings going up or see copper smelters in action, etc.  I took a tour of a huge nickel mine once.
