Overunity (what is it?)
Started by tinman, September 23, 2013, 11:40:00 AM
tiquila77
Hello guys, I have perfected a novel magnetic gate that I call "Ouroboros"(the snake biting its tail). The Ouroboros has the following characteristics: (1) It has a "sticky point" at its exit; (2) Its magnetic forces are uniform from its entrance to its exit; (3) When closed loop, its sticky point vanishes. Now from its mathematical model, it has a power-to-weight ratio of 2horse-power per kilogram. A sample of 9.37kg has a power of 21horse-power, a torque of 11newton-meter, and a speed of 13920 rev/min...
tiquila77
From 1995  till this year, I worked on a particular design, the prototype of which I built 3 months ago; although I succeeded in producing asymetrical magnetic field around the rotor, the design didnt work. Why? The torque was far lesser than the moment of inertia of the rotor. Early this year, I came across the U.S patent 5455474; and when I applied the method I used to produce asymetrical magnetic field in the other design, it worked well. The advantage of the new design is that I could easily adjust the torque arm, something I couldnt do in the first design. I want to approach NEST to see if they could help me...
Webby1:
I really don't know what you mean by "pushes the conditions over the top."  You seem to be implying that the rotating drum plus cavitation system will "take on a life of its own" after a certain input power threshold and start to produce over unity in the form of more thermal heat power out than mechanical power in.  That's not going to happen.  It's a huge mistake to just assume that "cavitation" is some mechanism to get over unity because it's not.
In fact there is a sobering point that I forgot to mention.  If the motor driving the drum is 95% efficient well there is a 5% loss right there from the get-go.   So a "dumb" water heater with a controller and a big resistive heating element is more efficient on paper and it's essentially zero maintenance.
Chet:
QuoteThe Soundwaves can cause a cascading chain reaction with tempertures easily reaching millions of degrees!
I am assuming that you are referring to the pistol shrimp and the sonoluminesence.  I will repeat that it's nothing more than the conservation of energy in action.  You take a certain amount of heat energy and you put it into a volume of water.  As the volume size decreases then the temperature must increase to hold the same amount of energy.  If the volume is really minuscule then the temperature can indeed reach millions of degrees.  It really doesn't mean anything in the searching for over unity scheme of things.
As far as the clip goes, I only glanced at it.  Perhaps it's somewhat akin to reading about a new "breakthrough" in solar cell efficiency every two weeks.  That's 26 "breakthroughs" a year, how many actually get into production?  If you put radioactive materials in a fluid with cavitation going on, perhaps the microscopic water hammer effects will induce nuclear reactions, I don't know.  Will there ever be a commercial "fission reactor with a cavitation catalyst assist" in our future?  I don't know the answer to that one.  Cavitation in this case is just part of the process, the energy is still coming from the nuclear materials.
I hope that you try to digest my little treatise about the cavitation bubbles and the sonoluminesence.  There is nothing magical about the pistol shrimp.  Certainly it's remarkable how it developed a mechanism to ccock it's muscles/ligaments/claw to create the effect it creates, but it's COE and all fully understandable.  Look at kangaroos, when they are running full speed their long ligaments act like elastic bands that store and release energy.  That's also remarkable.  Then there is that flagellar motor that has people going a bit crazy and talking about the big guy that may be in the sky, that's also remarkable.
tiquila77
The closed loop version of the ouroboros has a power-to-weight ratio of 2Hp/kg. It behaves like a piece matter falling in a bottomless pit, since the rotor accelerates endlessly in a circle. We all know that a circle has no begining or ending. Like the SMOT, the oroboros has its sticky point at its exit; unlike the SMOT, its magnetic field is uniform from its entrance to its exit; and unlike the SMOT, when closed loop, its sticky point doesnt come into play, for it siezes to exist!
ramset
MH
You really need to pay attention here,This is not Flatulent Bubbles in the tub.......
Completely heretofore unknown Process which was at first spotted in your "shrimp" Vid [around 1989]
and is evolving towards a complete new understanding which apparently knows few limits!
Take a look, you'll be seeing much more of this!
Synthetic Radioactivity [Piezo Nuclear reaction]
http://www.youtube.com/watch?v=ba-FeswwGNQ
Thx
Chet
Thanks Grandma
