Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
0 Members and 368 Guests are viewing this topic.
synchro1
We should be able to spin a nice size sphere up directly on top of this ceramic piezo chip set at the resonant acoustic magnetic frequency. Seated on a tiny. Ceramic bearing?
Number: SMD43T105F200S
Piezoelectric Ceramic disc. Silver electrodes being one on each side (S configuration).  Thickness mode vibration application
Piezo Material: SM111
Dimensions: 43mm diameter x 10.5mm thickness
Resonant frequency fr: 200 KHz±10 KHz
Electromechanical coupling coefficient Kp:≥40%
Resonant impedance Zm: ≤10 Ω
Static capacitance Cs: 1700pF±15%@1kHz
Test Condition: 23±3 °C 40~70% R.H.
fr, Zm, Kp => Thickness mode vibration application
Cs => LCR meter at 1KHz 1Vrms
Applications: Fish Finder transducer, Piezo transducer vibration, matter dispersion, Sonar Transducer Ultrasonic Sensor, Wall thickness sensor, Material stress sensor, Pressure sensor, Vibration generation, Piezo Energy Electricity harvesting, Piezo Electricity harvesting, Fish finder transducer, compression sensor, Piezo expansion sensor, biomedical probe and others.
synchro1
I tried it and it worked with two size balls. The spin effect produces a slow and steady clockwise rotation at 128 hz like the cymatic video. Not really very impressive, but relavent nevertheless.
synchro1
Here is a still shot of a spinning magnet cube acousticly levitated by ultrasonic waves over a transducer! Are we looking at the motor of the future?
        Electrical Efficiency
When an ultrasonic system is highly-efficient, most of the incoming electrical power is converted to mechanical vibration. For example, piezoelectric ultrasonic cleaning systems manufactured at Zenith are 95-98% electrically efficient.
synchro1
Lowering a halo coil over a levitated hypersonic velocity neo spinner would generate a mega OU COP! The coil can bounc6 and bleed the flywheel inertia from the rotor.
synchro1
Quote from: synchro1 on January 01, 2021, 06:54:03 AM
Lowering a halo coil over a levitated hypersonic velocity neo spinner would generate a mega OU COP! The coil can bounce and bleed the flywheel inertia from the rotor.
Tesla's Earthquake Resonator caused Richter scale trembling with low power pulses. The acoustic waves touch an electromagnetic hurricane off inside the magnet sphere.
At resonance the acoustic wave accelerates the electrons in the magnet sphere, then the sphere needs to catch up.
The Lorentz force causes the magnet elections to sheer and accelerate from the pressure wave and causes a self powered rotation at resonance.
