Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
conradelektro
Quote from: synchro1 on December 29, 2013, 04:02:32 PM
@Conradelektro,
What's your objective in the first place? You built some very primitive pulse motors, what are up to anyway?
Can you tell us where you feel you're headed? Your test model so far is nothing to write home about!
My objective is to enjoy myself. Others do paintings, sculptures or poems. I do little electronics experiments. I do not have to prove anything, I am not selling anything, I just have fun.
My builds may be primitive but they show how it is.
My objective with the "primitive pulse motors" is to try out special generator coils (like the "synchro coil") which according to some have magical properties (like no Lenz drag). I try to see the magical properties. If I do not see magical properties with my builds I report it. If I saw magical properties I would also report it (but so far no luck).
The next type of generator coil I try will be pan cake coils (bifilar and monofilar). I am also thinking about the "nail experiment" (bifilar has higher magnetic field strength than monofilar as some say).
The point of my primitive pulse motors is that the input power is low and exactly known. It is also known (up to a few hundred rpm) how fast the rotor spins with a given power input (from 1200 rpm to 2400 rpm the results can be reproduced by varying the supply Voltage from 10 Volt to 15 Volt). The resulting low torque and the known "no drag rpm figures" reveal immediately if a generator coil has "little Lenz drag" or just the "normal Lenz drag". The "synchro coil" seems to have "normal Lenz drag" and "normal output". (I know, my "synchro coil replication" is wrongly built according to synchro1).
So, I like to write home about the well defined parameters of my primitive pulse motors. And if the parameters are well known one might find and would be able to prove "magical properties". But usually magic only appears if the parameters are not known or wrongly measured.
I always hope to find some magical properties but magic seems to be more difficult than some believe.
Greetings, Conrad
synchro1
@Conradelektro,
I feel you threw a monkey wrench into the experiment and that no one has anything legitimate to gain from your jaundiced perspective. You're not the first flake to waffle under pressure from the "Trolls". I suggest you start your own thread, because I see nothing pertinent in any of your goals. I personally am through cooperating with you here because I can't see how your objectives relate to the thread topic. My advice to you is to try and consolidate your awareness and focus on a specific area then originate a new thread topic, because wide ranging interests such as paintings, sculptures and poetry seems not to be particularly germane to the area of "Self acceleration". Your pursuits have turned too eclectic. I believe it would help for you to create a new "Rubric" for your clutter box of experiments.
Best regards,
Synchro
synchro1
Here's a video that's germane to the thread. Ibpointless2 demonstrates how bringing a magnet into rotor proximity accelerates the rotor speed and lowers amp draw. It's just a rough prototype, but he makes his point:
http://www.youtube.com/watch?v=AN37ruFKrhs
Deepcut was involved in a magnet core output coil experiment with me on the Thane Heins "Lenz Delay" thread, then suddenly and inexplicably disappeared in the middle of it. Anyone ever heard from him? It's no wonder why experimenters grow paranoid and are willing to take a dive for the Geo Resource power elite!
conradelektro
A measurement with a little pick up coil. The pick up coil is the same type as drive coil and trigger coil. (Taken out of a 24V relay.)
The measurement is consistent with the "synchro coil" measurements. The output is about 600 µW at the same conditions. The "synchro coil" had an output of about 400 µW under these condition.
Conditions: 13 V (~25 mW) power supplied to drive the rotor, the pick up coil slows down the rotor from ~2000 rpm to ~1200 rpm.
Now what does this say: any magic coil has to produce more than 600µW under the same conditions in order to be magic.
Greetings, Conrad
synchro1
Here's a video from Igor Moroz of an aircore reed switch bearingless sphere that is very simple to build, loops BEMF to source and generates sufficient torque and flux field to get positive results:
http://www.youtube.com/watch?v=TGHAMMEm8lo
