Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
Magluvin
Hey Synchro
When you said you first noticed it with the diametric mag, was the diametrics(not spinning) poles in line with the axis of the coil a the time, similar to the way the magnet stacks as Conrad tried?
Also, what voltages should be expected from your directions on how to build it? I have a few 3/4 dia x 1/2 N52's. Very hard to separate by hand. Would they be satisfactory?
Seems odd if the poles of the mags are lined up with the coil, that there would be AC oscillation.
Mags
synchro1
@Magluvin,
One large diametric tube sitting side ways inside the core of a Tesla series bifilar coil produced the spontaneous charge. Two fairly large coupled diametric tube magnets coupled end to end sitting up and down tightly inside the bore hole of a series bifilar solenoid coil produced the spontaneous charge. One diametric magnet up and down had no effect. The original "Cook battery" consisted of two criss croosed primary and secondary coils in parallel to create two intermeshed LL tanks. My modified oscillator of a Tesla series bifilar with a resonant capacitor is actually an LCC tank, including the bifilar coils inherent capacitance. It dosen't help to overwrap the coil, and it should be of fairly thin wire. The series bifilar style connection is important.
I discovered that the diametric magnets placed as described, help assist the tank oscillation. You need to jump start the circuit by charging the capacitor a little or shaking the magnets up and down inside the core. Once it's started it should continue to charge on it's own. I'll add something about the diode. I used a fast switching glass germanium of the crystal radio type.
synchro1
Quote from: MileHigh on January 06, 2014, 09:21:55 PM
Synchro1:
You should start doing stand-up comedy at tech trade shows!
If you mean the "Jeff Cook" effect like we see in these videos....
http://www.youtube.com/watch?v=IMm70qQ5Jms
http://www.youtube.com/watch?v=UA-6PSO2A_k
....then it is yet another misfire.   All that you are seeing is the magnet in the tube "falling" into its lowest magnetic potential energy state.  You know like when you stand a pencil vertically on end and then it falls over and likes flat on the table?
Assuming that I am correct and I have the right "Cook" effect then it's just another example of ignorance leading people down a garden path of their own making.  There is no such thing as the "Cook" effect.  Yet another reason to open up a book.
This is just more "Curve ball mischief" from you. Get a life for yourself you malicious goon! You rediscovered Faraday for me huh; Bully for you! You got Conradelektro to cut the capacitor off my LC tank for testing you meat head!
The "Cook effect" I'm referring to is a "Parametric Power Transfer".
synchro1
Here's an active hyperlink on high frequency diodes:
http://www.youtube.com/watch?v=JcCLIwlbhLc&;feature=related
@Milehigh,
Tell me what rectifying terahertz frequency AC current directly into DC current through an MIM diode has to do with Faraday?
The rectenna is a novel combination of a micro-antenna and a tunneling metal-insulator-metal (MIM) diode. This combination will allow for conversion of electromagnetic radiation in the terahertz frequency range (AC) directly into direct current (DC).
http://coolcadelectronics.com/portfolio-item/infrared-rectennas/
synchro1
@Milehigh and Conradelektro,
I see the fine work you're doing on the Tesla coil thread, how did you guys conclude my "Synchro Coil" would work better with no capacitor attached?
