Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
synchro1
@Conradelektro,
You need to wire the specific components I posted to the thread onto the magnet coil and check for spontaneous charge. Once you succeed at that you can move on to testing with the spinning magnet rotor. The charge zone should be located outside the induction zone as tested for with a multi-meter. You can go about this chore at your leisurely pace. You'll probably need to special order the "Tunnel Germanium diode". I'm very impressed with the look of your pancake video, but I never maintained anything about the use of a pancake coil for output purposes.
Everyone knows how good it performs as a wireless power receiver. This is it's function on the "Synchro Coil". I never at any time alleged the Tesla series bifilar coil works better as an induction coil. It was a huge mistake to test my "Synchro Coil" as an induction coil and maintain that it failed to work. The "Synchro Coil" series bifilar is designed to work as a POWER RECEIVER COIL, not an induction coil!
picowatt
Quote from: synchro1 on January 09, 2014, 07:19:36 PM
Can you provide a part number for a "Tunnel Germanium Diode" suitable for operation in the THz band?
PW
Magluvin
Quote from: picowatt on January 09, 2014, 07:44:38 PM
PW
This is from a document from 1963.  Maybe they are better these days.
TYPICAL RCA TUNNEL DIODE • switching times to 75 picoseconds • peak currents from 1 milliampere to 220 amperes • broad application capability • gigacycle switciiing speeds
http://www02.us.archive.org/stream/RcaTunnelDiodeManual/Rca1963TunnelDiodeManual_djvu.txt
Mags
synchro1
@Picowatt and Conradelectro,
try a: 1N3712. In the meantime have a look at this "Leon Dragone Magnet Pump Video". You can see a closeup of the electrolytic capacitor and diode I use. The disk magnets on the coil are the most powerful available on the commercial market.
@Milehigh,
I prove here in this video, that I can generate power without moving magnets over the coil, outside the restrictions of "Faraday's Law". The magnets are in attraction. The coil is pulsed through the reed switch, then power is generated in the coil when the permanent magnet field reestablishes itself inside the coil! I produced this video to demonstrate the viability of the the "Synchro coil" theory you flagrantly scorned! There are no moving "Faraday magnets" in this magnet pump! Dr. Dragone maintained his simple magnet pump was COP>40.
http://www.youtube.com/watch?v=q5WSPMeWGdE&list=TLvfF6ZA57LvV7eDFDeue0XosYGWgsP5s9
Here's a second one with a clear view of the power reading:
http://www.youtube.com/watch?v=jBPKO9qSfGk&list=TLvfF6ZA57LvV7eDFDeue0XosYGWgsP5s9
synchro1
It occurred to me that if we ran a tickler coil down the center hole of the tube magnets in the "Synchro Coil", and pulsed it, we'd have a virtual the VTA, Vacuum Triode Amplifier, of Floyd Sweet. Floyd reported mega OU COP's!
Quote from Dr. Dragone:
When a permanent magnet is placed inside a coil, and the current in the coil is turned on, the coil's field can aid or cancel the PM's field. If the coil cancels the PM's field, the magnetic energy of this field is lost from the environment. Where does this energy go?
