Nikola Tesla's Discovery Of Radiant Energy and How It Can Be Harnessed For Free
Started by ptlam, October 01, 2013, 04:30:47 AM
ptlam
Nikola Tesla & His Discovery Of Radiant Energy to Produce Power
The discovery of radiant energy in 1889 (the energy in electro-magnetic waves) & converting it into free electricity goes back to Nikola Tesla, a Serbian-American inventor & engineer, who was particularly interested in the utilisation of electromagnetic waves & cosmic rays (from the stars) for energy.
He researched this at length but lack of funding eventually put paid to developing this concept into being able to provide free electricity for mankind, which is what he had hoped to achieve.
Furthermore he discovered that radiation from the sun & cosmic rays from other sources such as the stars, had the capacity to charge electrical conductors, ie a free power source that could be converted into electricity.
Tesla also recognized the fact that radiant energy, which is abundant & exists naturally, is the power source of the future.
You can build a device similar to Tesla's designs to check out the technology to see if it actually works as per the steps below;
Brief Guide To Build Your Own Radiant Energy Device To Generate Power
- Get an aluminium plate (or antenna) of any size (the larger the better but small will still work) & ensure that is polished & clean
- Make sure that the plate is well insulated by covering it several times with some sort of insulating material
- Suspend the plate as high as possible in order to maximize its exposure to the rays & radiation - this will allow for greater output as it harnesses energy from the atmosphere after which it is transferred into a capacitor which becomes charged (with electricity)
Connect an electrical cable to the plate to carry the current that is generated by the device to the capacitor.
An oscillator or tank circuit needs to be connected to the capacitor in order to discharge it & transfer the electricity to a transformer which will make the power available at a lower voltage that can be used to power household appliances.
If you build one of these devices yourself you'll see that the Tesla renewable energy generator does indeed work, however its effectiveness will be dependent on various factors such as the quality & size of the metal plate (or other antenna) you use & how high it's suspended.
While the voltage & intensity of the current produced will be proportionate to the size of the aluminium plate & the height of the installation, even a small plate that is not positioned very high should still generate a small amount of electrical current which should be enough to illustrate the concept of using radiation as way to produce electrical energy.
It should be noted however, that the above plan is not really comprehensive enough for you to build a thoroughly robust & reliable electricity producing device that could power your home although you could experiment yourself until you come up with the perfect product that is powerful enough to produce usable power.
Nikola Tesla's research & design has recently been developed & refined & has now been made available to the general public which will allow any reasonably proficient handyman to build his own electricity generating device which can be used to power appliances in the home.
PS - Find out exactly how you can use Nikola Tesla's discovery & plans to build your own practical electricity generating device for your home
or
just go to the following link to find out how the Nikola Tesla device can be built at http://buildmagneticmotor.com/
truesearch
Take your 47 bucks and contribute it to your budget for buying solar panels.  There is a worldwide glut of soar panels right now and overcapacity in the solar panel manufacturing industry.
