HHo (Hydrogen) and Diesel Injection...The Truth
Started by markdansie, October 17, 2013, 03:20:15 AM
ramset
Thanks Grandma
DOG
Hi Johan:
I am from Spain, what is the name of the soap? is the name kh7?
thanks
Johan_1955
Quote from: DOG on October 24, 2013, 11:03:47 AM
Hi Johan:
thanks
Hi Man,
Sorry for the delay, did miss the topic change announcement, old and busy!
With this below you find the AlCampo-Soap bottle photo, what we are using.
When you can not find these bottle's, just try A soap, and pre-mix it.
75% Diesel, 0.5-1% Soap, rest nice clean sweet water.
Test it in a simple diesel motor and straight compare the results.
A good soap for this, is giving with 20-25% mix, the same results as pure only diesel fuel.
The difference between 20 or 25%, is related to combustion camber shape, pre or direct.
Send you a PM, maybe we can see?
Regards, Johan
ramset
Johan
Old??
I hope the 1955 is not your birth year ?,if so you're still a young Man  :D .
Thank you for sharing this very good information,I will share my findings!!
Nothing but grattitude from here!!
Chet
Thanks Grandma
Johan_1955
Quote from: ramset on December 16, 2013, 11:33:56 AM
Johan
Old??
Chet
Hi Chet,
Thanks, and sorry for the delay, if you also did wait for that photo!?
If you, or some need, ask!! To many nice projects! ;-))
Fear for Emulsified Fuel:
There is far too much programmed fear around, induced from semi-advisors being: Hero or Senior member, so sorry also here!?
But here on Stefan's OU-Site, I feel always young, still a NEWBY, to little number of posts, so its not about the contents? ;-))
But its good and also in fully harmony with not mine but the sleeping outside world, leaded/dominated out of compensation.
The semi-advisors, when they here about: Emulsified Fuel, panic, mine Piezo-Injectors, if they knowing ......... ?
Piezo-Injector is just a more stupid injector, acting like a High-Pressure 2-2 ventiel, perfect for this with 1.8-2Kbar.
Diesel Fuel direct from EVERY pump, BP/Shell ....... contains water, this between a 2 - 4 % is very normal naturally, Benzine even more!
With this, not meaning the condens, that the to much water for the Diesel-Fuel to absorb, when its complete again, with the 2-4%.
About Emulsified Fuel:
Sorry, our current movies are very basic, but now YT lets our account being there! ;-))
The previous account White coat, fully explaining step by step, movies are in space .......
About our current simple YT-OT-films, with the 40-50% savings: Same recept of Emulsified-Fuel.
Only with HHO-gas, produced by same engine, and a back-Feed from the Exhaust for more Temp.
The last point of bringing Heat back is the biggest fuel saving: With our Heat-Recovery ;-))
When a motor has 10Kw, we use and produce 30Kw of Heat, only the piston-engine is still stupid design.
But with that 30Kw of Heat, you can do a lot: Google and build a Flash-Steam-Engine on you exhaust manifold.
This will double direct your engine Fuel-Economy from 30-35% to just over 60% efficiency.
Again: Google and learn about: Steam-engine's, build one behind your Big-Spender Piston Combustion waister!!
We did make & tested a Rotary-Vane-Engine, posted before, is far better, bit fuel on a Large Diameter of Rotor, (Torque).
Next time ..................
All I can say: People, grape a old one-cilinder diesel: Hatz, Farymann, Lister, Petter, ................ and jump over your fear borders!
Get alive again, advisors are talking out of own fear, killing with that the free thinking creating artists!
Kind regards, Johan
