Impulse Perpetual Machine
Started by vineet_kiran, November 02, 2013, 12:38:59 PM
vineet_kiran
A try to use mechanical impulse for attaining Overunity
hartiberlin
Interesting principle ! Please try to continue your experiments.
Yes, Bessler used probably also some kind of momentum, as pure lever devices do not work
for a gravity wheel.
There must be something dynamically and he used probably some kind of conversion of centrifugal
forces to unilinear forces. Centrifugal and Centripetal forces can be created for free in a rotationg system and
if you succeed to convert them to linear motion you can build a running Bessler wheel !
Good luck !
Regards, Stefan.
TechStuf
There must be something dynamically and he used probably some kind of conversion of centrifugal forces to unilinear forces.
In multi-axial systems, consider that moving the center of gravity takes less energy than may be produced at the periphery of the system.  Even near the periphery, the employment of multi-axes can significantly shift the CG of the aggregate peripheral mass such that the modulation of swing amplitude can effect energy gains.
Employing such systems, which use gravity to produce varying swing periods that are tangentially force coupled, effectively makes us of the main axis as a virtually "absolute" stable reference point.  Which is roughly analogous to a windmill acting as an "absolutely" stable point from which to gather energy from wind moving relative to it's position.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
Newton II
A momentary collision definitely  causes physical movement.   Magnifying it using levers is a very interesting concept.
http://en.wikipedia.org/wiki/Newton's_cradle
LibreEnergia
Quote from: TechStuf on November 02, 2013, 07:57:38 PM
TS
This is absolutely untrue. No matter how you attempt it momentum and energy of a system is conserved.
If you believe these quantities are not conserved then show some experimental evidence of it occurring.
You don't have the remotest chance of that , because it doesn't happen.
