Electrostatic motor
Started by d3x0r, November 18, 2013, 04:46:08 AM
PiCéd
Normaly when we turn a motor or a generator we produce electromagnetic and electrostatic electricity but the second one is never used.
at least it seems to be that thing...
synchro1
@Lidmotor adds a capacitor:
http://www.youtube.com/watch?v=CfHTZkCrS4A
@Lasesabre's got a strong contender for atmospheric motor:
http://www.youtube.com/watch?v=do4IO_U3B5o
gauschor
This brings me back again to the original problem: "only then will electric charge persist in the capacitor, when it is charged with sufficient amperage, otherwise the charge will vanish quickly."
So how can we charge up a cap with electrostatics? The only way to get an amperage seems to be impulses via a spark gap. While this works, general electrostatic devices require significant time to charge up and provide a lightning thick enough. If there was a way to do it without...
Has anyone tried a magnetically quenched spark gap (someone in the Kapanadze thread mentioned this) to charge a cap? Note that you need to separate magnets and spark gap via plexiglass (maybe even a vacuum tube around the spark gap?), so the lightning can't jump on the magnets, but this way you can put the magnets very close to the spark gap. But who knows, maybe you'll see a difference only with multiple quenched spark gaps... oh well this just sounds too easy.
Hmm... maybe the rectifier is the problem. If I use a simple 4-Si-diode rectifier circuit to catch the impulses it might kill the "magnetically enhanced" charge effect. Maybe that's where another type of rectifier must be used... some old tube rectifiers or so...?!
PiCéd
With the ping pong ball of Thomas Kim I have this theorical idea.
Maybe it will perform the cop realy near to 1, maybe it will overpass it but for the moment I realy don't know.
gauschor
Not wanting to go too much offtopic but I just found on youtube a guy having some vids about a magnetically quenched sparkgap http://www.youtube.com/watch?v=hwVvHgbJdzA (there are more vids on his channel too)
And one of his comments "By using this magnetic quench approach the inpulse duration is shorter and thus a higher instantaneous power is produced" and "I think the sound is higher/louder because the discharge is more abrupt. The energy from the capacitor discharge is not allowed to be a "soft" discharge, it has to happen more suddenly because the lorentz force is pushing on the arc as current flows. This probably causes the cap to charge a little higher before it can discharge again, and so, more energy louder sound."....
