DIY Homemade PVC Wind Turbine Blades
Started by ELEMAN, November 21, 2013, 06:35:50 PM
pvc turbine blades
DIY
1 (100%)
Homemade
0 (0%)
Total Members Voted: 1
ELEMAN
http://www.youtube.com/watch?v=NolB5BbQnBc&feature=c4-overview-vl&list=PLT7Zi_DRtP7fMFdNnhG7nQXj2YmSYGXkt
http://georgechaniotakis.blogspot.gr
First you need a pvc pipe should have a diameter of 10 cm. One pipe can make four blades. "how big do you need them" my blades is 5mm thick and 50cm long. The material are very light weight and cost effective!
Music cover from HYPERDROP https://soundcloud.com/hyperdrop
crowclaw
@ ELEMAN
Nice video... I made mine the same way with PVC drainage pipe. 3 blades 2ft each attached to a treadmill motor. My tail plane and support was also pvc 2" pipe and pvc sheet for tail  weighs in at about 2Kg. All works OK but  not high enough,. Could do with something that would produce a good output at low rev's though. I like your AC motor conversion, what was the motor used for! Kind Regards Crow
ELEMAN
Thanks for your comment. :) The motor that I put is this ...
http://www.youtube.com/watch?v=v_ZuyoYqJ2s&feature=c4-overview-vl&list=PLT7Zi_DRtP7fMFdNnhG7nQXj2YmSYGXkt
The motor is from refrigerator axial fan. Description- rated power 16 W - power supply 230/240 V - electricity 0,45 A - power input 65 W - RPM 1300/1550 r/min to make this powerful permanent magnet generator wind.
crowclaw
@ELEMAN
Many thank,s keep posting    Crow
