How to make multiple Kicks
Started by Neo-X, November 23, 2013, 10:31:20 PM
Magluvin
Hey Bruce
In this vid  The SM Kicks    https://www.youtube.com/watch?v=-wnEr0O75Sc
Your scope is connected to the transformer/magnetic pickup?     Ground and probe?
Then you have your short piece of wire near or inserted into the transformer/probe?
Its hard to tell what is going on for sure there. ;D
Mags
Magluvin
Could it be that in the vid I replied to, that the voltage 'source' from the scope is being picked up 'capacitively' between the probe and wire, being that they are all in one unit, the scope?
It doesnt look consistent on the scope as per the taps.
Mags
Magluvin
Lets say I have a trifilar coil on a transformer core.
If I put 2 of those strands in series with 2 leads out, and connect those to my scope, then just have a 12v batt at the other end of the table and get an alligator clip lead from the + of the batt and just tap it to one end of the 3rd strand, I will get output from my bifi to the scope?
Mags
Magluvin
I have a little scope that has a sig gen.
The series bifi windings ring near 10khz.  Applying 1 lead of the sig gen to the 3rd strand, other end of strand open.
1v square wave from sig gen produces 10v p-p on the series bifi.  Nice ac output considering square 50% dut in. Adjusting the duty cycle lowers the output, but still a sine out. No spikes. ???
Next try will be using a sig gen from a separate source(scope/gen no. 2  same model) to eliminate direct capacitive effect between the scope and sig gen. There will still be a say ambient/atmospheric capacitance between equipment, so we may have some output.
Mags
Bruce_TPU
Quote from: MileHigh on December 01, 2013, 10:13:19 PM
Bruce:
It's more like reality needs to get its own fair share of time on this thread.  Take for example, the case of Daniel Nunez.  He put up some clips of pulsing coils on YouTube and claimed over unity.  Many commenters told him that he was wrong and that he was not making his measurements correctly.  He got an article or two on PESN, and the same comments were repeated.  A few months later there is Daniel Nunez at the Breakthrough Energy Conference still pitching his silly coils and claiming over unity.  So Daniel Nunez was intentionally ignoring all of the advice telling him that he had nothing and his measurements made no sense.  He just continued repeating the same thing over again at the conference.
He charges $600 for his "bird's nest" coils.  They are nothing more than magnet wire made into a fancy form.  The "bird's nest" form is totally meaningless, and utterly useless.  You are better off making an ordinary coil.  Daniel Nunez makes coils, but in fact he doesn't have the slightest clue about how a coil works.
So where does that leave Daniel Nunez, Bruce?  He is charging outrageous money and making nonsensical claims for his coils.  In watching several of his clips it is so painfully obvious that he knows next to nothing about electronics and nothing about making proper measurements.  His is just an ordinary Joe Blow that knows next to nothing.  He is just trying to cash in on going "green."  In my book, in my opinion, that makes him a criminal.  He should be exposed and put out of business.  If he persists he should be prosecuted for criminal fraud and sent to jail.
Your first YouTube clip link is a bad link.   The second clip you linked to works.  One more time, your talk about tapping into the electromagnetic field of the Earth.  That's pure nonsensical fantasy on your part.  The only field from the Earth that you experience is a DC magnetic field.  When you first start learning about magnetic fields you learn that they must be changing with respect to time to have any affects on other circuits.  This fact will not go away just because you don't want to believe it.  You can carry on on autopilot if you want to for the next several months and several more YouTube clips and simply ignore this reality but eventually it will come around because you simply can't escape it.
When you lay your hand on the mircowave oven transformer coil you are transferring the 60 Hz voltage hum that your body picks up into the coil.  It's your body acting as an antenna for the 60 Hz mains power hum that ultimately causes the spikes on your scope display.  You can even see what looks like a sine wave envelope on the amplitudes of the spikes, which could be confirmed with more testing including changing the time base of the scope.  I can't tell you the exact methodology for seeing the spikes on the scope display because your clips are very poorly documented, but I am pretty certain based on what I see in your clip that that's what's going on.
If you want to educate and give people a real chance to comment on what you are doing then you have to document yourself properly.  That means that you have to make a schematic of your setup that is clear and readable.  You allegedly have a "magnetic field sensor" that consists of a loop of wire and a black plastic project box.  You have to tell us what your magnetic field sensor is if you want to be credible.
If I had access to your bench and started to investigate what you were doing, it probably would not take me too long to figure out exactly what is going on and it will certainly not be what you think is going on.  You simply don't have the electronics knowledge to understand what is going on based on my reading dozens of your postings and looking at many of your clips.  It's up to you to educate yourself if you want to take this stuff seriously and if you want to be taken seriously.  I am "raising the bar" for you because you are trying to claim a leadership and teaching position.
If you want to properly document your experiment in the second clip and make a schematic and show the various signals, and show what you have in the black box, between myself and others around here we could probably collectively figure out what is really going on in your clip remotely.
You NEVER listen, is why you are uselessbfor anything but being a talking head!
One last response to you...
The MAGNETIC SENSOR ONLY PICKED UP MAGNETIC FIELDS.  THESE ARE MONTHS OLD VIDEOS.  I LATER MOVED ON TO USING A RESISTOR AND NO MORE MAGNETIC SENSOR.  I KNOW MY HAND WAS ACTING AS An ANTENNA.  I said in my post of the videos to IGNORE THE CONCLUSIONS HEARD IN THE VIDEO.
I am showing magnetic kicks from an antenna souce THAT IS THE POINT.
