Super simple way to see proof Pseudo Solid principle works using ring magnets
Started by gammarayburst, December 03, 2013, 04:51:41 PM
gammarayburst
The Ring magnet drawing is not for showing overunity work but to show the basic principle of Pseudo Solid operation. It's shows how a magnetic field can move with it's magnet down a piece of iron without any drag. Any drag that may result is from eddy current drag and can be eliminated many different ways such as different materials that resist eddy current formation and also by laminating the material in razor thin layers. The second drawing attached shows how the Pseudo Solid principle can be applied in a system for overunity.
Thanks,
Butch LaFonte
Floor
@GammaRayBurst
               I think I might enjoy doing a few drawings that explain your work on this topic (as I understand your work).
I'm thinking also of phrasing  a few of the "rules" which define and govern the principles (as I understand them).
If I may have your permission to do so, and for your review / corrections, I will [post them here ?
                                                       Cheers
                                                           floor
gammarayburst
Quote from: Floor on December 08, 2013, 06:19:54 PM
@GammaRayBurst
                                                       Cheers
                                                           floor
Floor, I would very much appreciate you doing that, yes please go ahead! I need all the help with this that I can get. Thank you so much, Butch
Floor
                Some explanation of the Pseudo Solid principles.
                                      Cheers
                                              floor
gammarayburst
Quote from: Floor on December 09, 2013, 08:38:11 PM
                                      Cheers
                                              floor
Floor, great job on the papers you did! That will help people so much understand the principle. There is one area that you need to cover though.
It is when you have two magnets with their poles north poles side by side and in between two plates and the plate set is attracting another plate set that has no magnets in it. Then when that empty plate set is flush with the magnets plate set you slide one magnet in Pseudo Solid fashion to the empty plate set and then the two plate sets go into repulsion to each other and move apart.
