Super simple way to see proof Pseudo Solid principle works using ring magnets
Started by gammarayburst, December 03, 2013, 04:51:41 PM
LibreEnergia
Quote from: gammarayburst on February 11, 2015, 02:54:41 PM
Profitis, No I never in my life have seen a true self sustaining magnet motor. I do feel that if I had the funding I would have one based on the Pseudo Solid Effect. The power in to the power out is so positive it would for sure work. Building a machine that can maintain .005" air gaps will cost a lot of money.
I'd fund it, if you could quantify the above statement with accurate measurements.
profitis
@dieter weigh and shove the gold leaf and a chunk pyrolusite into soda ash sol and chek for faradays law.you'l get a shock.@gammarayburst well sir I suspect if you begin to investigate these ideas in relation to electromagnetism you might just tilt past that thin red line into ou territory.concentrate on using different materials too eg cobalt,nickel,bismuth and interesting things might happen.I was just discussing the smot device the other day and suggested using a nickel ball instead of the usual iron.different materials react differently to a magnetic field.I suspect even paramagnetic materials eg titanium may be worth investigating
Floor
@LibreEnergia / GammaRayburst
I would be interested and willing to diagram and illustrate a set of measurement procedures
methods and simple devices that will quantify the forces at play in a specific
"pseudo solid" interaction.
                   floor
Floor
@Gammarayburst
Here is a rough outline of a measureing process.
It would be up to you  to decide on which or
what Psuedo Solid operations to measure, as well
as the specifics of magnets types, steel bar sizes
and so on.
Please find the attached file P S measureing.PDF
                             cheers
                               floor
gammarayburst
Quote from: Floor on February 15, 2015, 10:36:45 PM
@Gammarayburst
and so on.
                             cheers
                               floor
Floor, I am having trouble understanding what is being measured and where the work in and work out takes place?
Butch
