An interesting phenomenon I found
Started by xenophed, December 18, 2013, 07:17:45 PM
xenophed
I was working with LaserHacker circuit as most have for at the moment  it is the closest we  have been but a side issue. I wound a bi-filler bode coil and found a new way to drive it with a  300% reduction in power use. It is wound just like his but over steel welding rods instead of ferrite cores. http://xenophed.wordpress.com/2013/12/08/free-energy/ this describes the set up and after  it is reviewed I will release  more but here is a video http://youtu.be/ukuMi6JjWa0 on youtube.  All I will say is there is a lot more to come but I welcome all to try this simple circuit and reply
xenophed
e2matrix
I think this one blew right by everyone.   xenophed has a circuit here that is likely getting MORE POWER OUT THAN INPUT by the battery.  He didn't claim this here but on his blog and on laserhacker's site it is more clear how BIG this may actually be.   I plan on giving this a try and think others would also if they had seen his write up on his blog and laserhacker.com.
This is a very unique bifilar or trifilar setup with info gleaned from Tesla as well as lasersaber.
xenophed
Hello again,
I often sit back and watch people and events play out as it is the best way to learn,play the sponge so to speak. My initial results blew my mind and it was at that point I knew I had to investigate this. What I have found is that by driving the bifilar coils out of sync so to speak it levels the current in the two coils  (primary and secondary. It does achieve over unity in a since that the output  voltage is NOT important  so if we say apply 12 volts @ 1 amp.  on the input and make the secondary 10X then we go from 12 watts to about 110 giving that it still leaves about .07% loss instead of the .87% we currently have. I will help everyone out a little more by saying that ANY BIFILAR COIL will work on the primary side.as long as we drive them out of phase with each other. Also I do have another circuit that the emitters of the transistors are tied to the respected power inputs, It starts up easier. Please understand people that I broke my neck a few years ago and have very bad tremors and no income so I have accomplish all of this using part out of old discarded electronics. I know with my personal readings that it produces about a good gain at higher voltages say 120 ~ 1K volts. Remember the core or the coil is not the real secret but the coil driver circuit is. Hope this helps everyone and I will reply to all emails.
dieter
Sounds amazing. I guess somebody soon's gonna say naay...  I like the simple and elegant design. Would be nice to get details. tetrafilar coils, all in parallel?  How about a parts list hehe.
I wonder what happens here. Seems like the current and voltage is wiped up to a max, two standing waves. Normally such resonance is used in RF, not in Transformers. What if the stress of alternating resonance releases energy "out of space"?
I take it you're not kidding us, so if your measurement is correct then this is the breaktrough everybody is waiting for.
300% , did you test this with a real load? What is the output anyway, an upfold sawthooth?
Did you think about to self-supply it.
Thanks for sharing.
PS. What is L1 and L 2, Both seperate coils with 2x bifilar wire and their own core, or are they the 2x Bifilars of one coil??
