UFO coil
Started by DreamThinkBuild, December 21, 2013, 02:25:26 AM
DreamThinkBuild
Hi All,
I'm sticking this in the half-bakery oven because it's all speculative pie or fruit cake, depending on your views of the subject.
This was inspired from Azazel8867 after reading his alien races book, what caught my eye was the field lines from the ship on page 102-103.
source:
His Youtube page is here:
http://www.youtube.com/user/1SANTORI/featured
The alien races book here:
http://en.calameo.com/read/002667888b58fe4b9c77d
If you want some more back story on Azazel/Santori and discovery of book:
http://www.youtube.com/watch?v=nsxHBBwcZ8U
The first picture shows a normal solenoid coil top is north, bottom south. With a ufo coil we push the top down so it touches the south. The easiest way to visualize this is take a squishy ball and squeeze it with two fingers till the middle meets where it is pinched. The sides will bulge outwards. When this is powered the N and S of the coil will be feeding into itself. Like a simulated black hole, with accretion disk forming through the outer edge of the midpoint, singularity in the middle.
If the bottom coil is reversed wound we would have a north at each pole with the south running transverse along the center. This can be inverted to have south at each pole and north along the plane to the center. An AC wave would alternate between the two. Images ufog10 and ufog11 show this effect. Ufog1 shows if the winding is wound all in the same direction.
Constructing it would take a 4 part former, two curved center pieces then a two curved outer pieces. This could also be formed as a sphere which may be easier to test. A hard foam craft store sphere hollowed, cylindrically, in the middle could work. Use pins to hold the wire in place. Wire the inside former first then splice to outer coil and do the same for bottom. The splicing would probably be the most difficult if multiple layers are used, maybe litz wire. Maybe someone sees an easier way to wire to test?
The next set of images are visualizations of field control across the surface of the ship. By changing the core and surface field polarities we can shift the field around. This would be different than one coil, controlled plasma along the surface would be more likely than heavy wires. This doesn't take into account that the entire ship would be coated with a diamagnetic/superconductive material to create a gravito-electromagnetic meissner effect. This is all speculation.
http://en.wikipedia.org/wiki/Gravitoelectromagnetism
http://einstein.stanford.edu/SPACETIME/spacetime4.html
Interesting patent application:
US 20120092107 A1 - Propulsion system using the antigravity force of the vacuum and applications
https://www.google.com/patents/US20120092107
That patent has some relationship to the information of Boyd Bushman.
http://www.youtube.com/watch?v=hNPBYtJyfZo
Every interview with Boyd seems like he always wants to say more but then refrains.
Bob Lazar mentions an interesting tidbit in one of his interviews. At 17:30 in this video he talks of how the ship moves by creating a distortion in front of it.
@17:30
http://www.youtube.com/watch?v=3VWmNm6J09M
Ufog3.jpg - Ufog5.jpg show a simulated effect of shifting the core field of the ship to one side.
Image ucoil6.jpg show a possible unipolar generator using the field from ufo coil with either spinning/shifting fields of interior or exterior.
http://www.plasma-universe.com/Unipolar_inductor
I had an audio file from someone who happened to point a high gain parabolic mic at a ufo, the sound when analyzed looked like a low frequency sweeping Alfven wave.
http://mysite.du.edu/~jcalvert/phys/mhd.htm
Attached also is the data points which can be edited in Excel and Octave/Matlab script in .pdf to convert to vizimag script. The original data points came from b-spline drawing from 3d program and converted to points.
Happy holidays. :)
DreamThinkBuild
pictures continued...
Reiyuki
Haven't a clue if it would work, but those are some really cool looking pictures.  Thanks for the contribution. ;)
aluka
Ist sehr einleuchtend gemacht wirklich Klasse !, da kann ich auch etwas zu tun.
Auf dem Foto des UFO von Rosswell welches in Hangar 18 von Wright Patterson Airbase gemacht wurde
kann man eine ähnliche Struktur erkennen.
