Lenzless resonant transformer
Started by Jack Noskills, January 17, 2014, 04:58:15 AM
dllabarre
Jack
Yes.. Well Done.
Can you post a pic of your build?
I'm going to try to replicate it this weekend if I have the parts.
DonL
verpies
Quote from: Jack Noskills on January 17, 2014, 07:11:14 AM
I had only two halogen light bulbs. I connected one, there was light, and then second bulb which lighted up and first one dimmed just a little. So not enough power to run both at the same time.
Do you think that this circuit is OU?
zcsaba77
Quote from: Jack Noskills on January 17, 2014, 04:58:15 AM
I have discovered resonant magnetic flux effect and made a device which I think is electrical version of Tesla's earthquake machine. I can now make a device that is small and powerfull enough to power cellphones and PCs. This level is enough for me, proof of concept. I believe this can be scaled up but I don't want to take all the fun so I am asking you to join the party.
Builder, your job is first to replicate it and then see if it can be scaled up. All details are in the pdf. It falls well in the 'so simple you will laugh' category.
Abstract from the pdf:
This short paper describes a simple method how to build a lenzless resonant transformer. Lenz law is not violated but it is used to create more efficient transformer. Without Lenz law this setup could not work.
First some simple tests are presented which forms foundation of the device. Then based on the results of these tests I built the transformer which confirms my test results. It is important to understand the method which will give you understanding. When you understand it you can build it using different components.
Have fun and be safe!
Hi Jack
Are you used soft steel or ferrite core on your device?
regards zcsaba
T-1000
Hi there,
I would like to contribute something here as well:
http://youtu.be/PUcUvcoln-Y?t=2m45s - The JB Lenz-less motor
http://patentimages.storage.googleapis.com/pages/US555190-0.png (top left) - The N. Tesla (Lenz-less??) generator (not described in detail)
http://youtu.be/Zu4pzvkSkzo#t=0h12m00s - The shorting of toroidal generator without almost any reaction to motor.
They are directly related to this topic and to each other - please look closely on coils winding directions and amount of windings between 2 coils, the most important thing is there to get around Lenz... ;)
P.S> Also that is directly related to http://freeenergynews.com/Directory/Magnets/Leedskalnin/Magnetic-Current_Edward-Leedskalnin_51pp.pdf
Hopefuly that will bring to understanding of what is most important there.
Good luck!
Dave45
