Recover energy from temperature
Started by rc4, January 20, 2014, 05:46:59 PM
MarkE
Quote from: rc4 on January 22, 2014, 07:37:01 AM
If I use valves for red surfaces I can compute force on magenta walls. The mean of pressure is 0.45 bar so I need to give PSe but pressure is lower.
RC4 perhaps this will help:
Cut your machine in half at the point of greatest restriction and the point of least restriction.  Now what you have is a pair of horns.  Now pull them apart.  Do you agree that if we take either horn that we must apply external work to move air through that horn one way or another?  If you agree with that, then why should gluing two horns back to back change the situation?
rc4
In the last message it's not PSe but PSe' I give.
Yes, I'm agree with you for 2 horns. But here, look at magenta walls they move at V, but I don't need to move e because valves move to the left in the same time. The mean pressure is 0.45 bar like when I recover energy. But for me, dV is lower due to the difference of e -> e'. I would like to understand this point. And if I recover energy from red valve, the force if Poutside - Pinside in the volume, but here it's logical the distance to move is not e but e', no ?
MarkE
Quote from: rc4 on January 22, 2014, 08:13:16 AM
rc4, imagine a large cross-section square tube.
Do you agree that the pressure is constant inside and outside the tube?
Now imagine that we have another tube section with a smaller cross section and a flange plate on the left where the plate is at least as big as the cross section of the first tube.  Imagine that we lower this tube into place so that the flange plate lines up with zero clearance to the right hand side of the first tube.
Is the pressure now different inside either tube or outside the tubes?
PiCéd
Since energy can not be destroyed in any case I was wondering if "S multiply by T" was especially the heat in loule of a material ...
S = entropy
T = temperature
rc4
@MarkE: I understood my error. Thanks  :)
I have another idea if you can help to find the error.
The goal is to let gas to compress each volume from 0.5 bar to 1 bar without lost energy, after put this volume inside a container where there is 0 bar (or vapor pressure) without energy, after recover energy from depress gas from 1 to 0.5 bar and after pass this volume to the first container.
For this, I use gears with teeth like drawing show. Gears don't give a torque or a force, they are only there for assume sealing. So the energy is not recover from gears but from volume when they pass from 1 bar to 0.5 bar: PdV.
For move in a volume inside vacuum container, I place 2 volumes of 1 bar inside a tooth of gear 1 or 2, I can pass without energy, no ?
For move out a volume inside 1 bar container, I place 1 volume of 0.5 bar inside a tooth of gear 3 or 4, I can pass without energy, no ?
Gears 1 and 3 (or 2 /4) are fixed together so they turn at the same rotational speed w. But like radius of gear 3 is 2 times higher of gear 1, when I pass a tooth of gear 1, I pass 2 teeth of gear 3. So the number of volume that move in or move out is the same. I keep always the same number.
Now, gears must assumed sealing (no gas escape), it's possible to imagine gears with very few space between teeth in theory. So I can think the problem come from here. It's possible to reduce number of gears. Here I choose diameter of gear 3 = 2 * diameter of gear 1 and this allow to depress gas from 1 to 0.5 but it diameter is 1/3, I can depress to 0.33 bar and recover more energy.
So what's wrong in this case ?
