Wasif Kahloon's Magnet Motor
Started by NTesla, January 29, 2014, 12:31:49 AM
MarkE
Quote from: T-1000 on February 07, 2014, 02:49:58 PM
Seems you do not know what Gary Effect is - http://www.linux-host.org/energy/tmagnet1.htm
Also the tricky part is precise engineering for magnetic switching between two magnetic poles and not magnetized metal(which is giving resulting magnetic pole)  between them on same metal cube cast and many failed to do that.
Only few people was able remove obstacles for making it to give energy out of the magnetic field:
http://searlsolution.com/technology2.html
http://www.rexresearch.com/sweet/1nothing.htm
http://peswiki.com/index.php/Directory:Leedskalnin_%22Perpetual_Motion_Holder%22_%28PMH%29_Bond_Effect
P.S> Please feel free to create separate thread for people who are willing to do lots of hard work for making magnetic motor a reality instead of just having the dream. The community can achieve this like with any other open source science project as there are brilliant minds around the world who can make a difference if they will share and work together...
T-1000 what you call the Gary effect is just ordinary magnetic field distribution.  You have several options:
1) You can take my word.  But no one should just take someone else's word.
2) You can check my statements against reliable references.
3) You can try and come up with a configuration in either simulation or a real experiment that does what you hope.  Again, don't just take my word.  Go and look at the multitudes who have attempted to create a magnetic field with the properties you seek.  All failed.  A physics textbook explains why:  No matter how complex you make the field, there is always a location of minimum potential energy.  It takes real work to move anything away from that spot.  The best you can do is reduce that work to virtually zero.  That requires reducing the field strength to virtually zero.
This presents a learning opportunity for you.  You can view any of TinselKoala's excellent magnet experiments where he demonstrates how to check to see if one configuration or another depletes energy or improves the efficiency of a mechanical device.  If you set-up experiments with the same sort of good null experiments that TinselKoala demonstrates then you will be in a good position to evaluate any configuration that you might like to try.
issacjohnjj
MarkE
He's got the same mechanical issues that he has always had that prove he is faking.
