Can someone smarter then me tell if this will work?
Started by MacGyver, August 21, 2006, 03:49:35 PM
MacGyver
I've never built any permanent magnet motors, I stumbled onto your forum yesturday and had an idea to get over what you all call locking.
If you've seen it before, let me know that too.
Ok, I can't draw, so no pictures, but I'll try to describe what I'm thinking of.
First, setup like most others i've seen with say: 16 cylinder magnets in the outer edge of a rotating disc, so that the pos. is on one side and the neg. is on the other side, depending on size, take say 16 of these discs, and put them on a shaft thats curved into a full circle, do the math so that the disc to the right of each one is set just before the locking point, do the same all around the doughnut, so that each plates magnets are repeling the plates next to them, I think the total number of plates may have to be odd though. +--++--+
Anyway, each plate wants to push the plate next to it away (rotate away), and this folows around the circle back on to itself, which would keep going.
I don't know if alot of plates would be needed to make the angle to each other less, or if the edge of the discs inside the doughnut would repel enough on their own.
Can someone tell me the reason why this is wrong.
Almost forgot, perhaps a sort of ratchet on each disc, so they only will rotate one way.
Sorry.
Duranza
Trying to picture it here... Kinda tough without actually looking at something... if you can plz draw a Paint sketch of your device and post it here.. I think you might be along the lines of the Bowman's motor...http://www.pureenergysystems.com/os/MagneticMotors/BMM/
The only way to Validate is to Replicate!
MacGyver
tbird
hi MacGyver,
from the drawing in the center left, the disk would have only enough movement to get in balance.  probably each magnet on the first disk would end up half way (if even #) between the mags on the next disk until all forces were equal down the line. then it would stop.
i think what you were trying to describe would be like a wave effect.  to see this better, if you straigthened out the rod so all disk were inline and turned the first so it made the 2nd turn which made the 3rd turn and so on until it reached the end.  now to make the last turn the first, you want to bend the rod into a circle so the last will effect the first.
does this sound like what you were thinking?
tbird
It's better to be thought a fool than to open your mouth and prove it!
MacGyver
yes, like a wave, if it was straightened out.
if the discs were heavy enough, would the momentum keep it going?
once it was moving could a small pulse be applied into it to keep it from reaching a balance.
would that many magnetic fields in motion, if inducted into coils surrounding the whole thing , be larger then the small kick needed to keep the whole array of magnets moving around?
if not, could you use ALOT of discs in a LARGE doughnut, if they only can go one way, and they all are the same, wouldn't moving one, move all the others, or would the coils surrounding it create alot of drag?
