GEM = God's Electricity Multiplier
Started by that_prophet, February 06, 2014, 09:19:10 PM
that_prophet
Quote from: that_prophet on September 24, 2016, 07:02:21 PM
what reasons,,, you are not talking about the same laws that this runs on,,, electrical laws or thermodynamics do not apply here. This is simple pulley mechanics = 100cm circumference pulley turns only once + this 100cm of belt coming off it can turn 1 to 10 1cm circumference pulleys 100 rotations each. So, if you use 10 mini pulleys, you would gain a multiple of 10 X 100 = 1000 units of AC electricity,,, all from the one single spark of DC current, that drives you 100cm circumference pulley
Lenz law sounds like something electronic, when this works om simple pulley mechanics = 100cm circumference pulley only turns once
+ this gives you 100 turns, X,(times) the # of 1cm circumference pulleys that you attach.
If you attach AC generators to each of these 1cm mini-pulleys,
you would gain 100 units of AC electricity, for every 1cm pulley that you attach.
This could be massive amounts of free AC electricity,
if you added 10's of these mini-pulleys then you would gain 1000's of units of AC electricity,
all done with one spark of DC current, (practically zero)
that_prophet - Re: use pulleys to multiply total # of rotations = AC electricity
Quote from: citfta on October 14, 2016, 01:05:13 PM
I don't understand how you can be so dense.  You have had numerous people tell you that your idea will not work.  That is because we actually have experience working with motors and generators.
REPLY BY ME
I don't understand how mankind be so dense, to not see that this use of pulleys does not involve torque, but simple multiplication of rotations = multiplication of AC electricity. The AC generators are just winding up massive voltage, to turn over your DC motor, only the once, + no current, as you only need one spark to have this self powering.
Now try and tell me that you would not be able to get one spark of DC output,
when you have 1000's of units of AC electricity to work with
citfta
sm0ky2
When a generator is under load
i.e. - charging batteries or powering a device
Increased rpm = increased torque required
To turn the generator
If you gear it to a ratio of 100 to 1, you will
Require 100x's the torque to turn the smaller
Gear/pulley/lever/etc.
If this is an impulse from a dc motor,
This directly related to current draw and an
Increase of input power.
Qumogens are like gremlins, don't get them wet.....
that_prophet
Re: GEM=(Geometrical Electricity Multiplication)
« Reply #61 on: Today at 01:09:57 PM »
by that_prophet@yahoo.ca
= joe Lynch
Just one of His Creations
Using pulley mechanics to multiply AC electricity
I was hoping that I could enrage many deceived people,
--- once they saw just how super simple this idea is, that these evil spirits are desperately hiding
--- --- but I have not yet been able to break this solid hold that they have on the masses
--- --- --- until now,,,
How can you not be multiplying AC electricity, when you pay for only one rotation of a DC motor,
--- with a 100 cm circumference pulley attached. (costing higher Voltage + 1 spark of current)
--- --- to crank it over once, gaining 100 cm of moving belt
--- --- --- and then getting back 1000's of units/cycles of AC electricity
--- --- --- --- by running your 100 cm of moving belt past 10 mini-pulleys of 1 cm circumference
--- --- --- --- --- thereby multiplying your rotations to 10X100=1000
--- --- --- --- --- --- ( HOW CAN YOU GO WRONG )
(WHAT I CAN'T BELIEVE, IS HOW GREAT A HOLD THAT EVIL FORCES HAVE ON MAN)
--- to hide this super simple method of multiplying our AC electricity
--- --- from His ministers even
--- --- --- as I have tried to get 3 or more churches to patent this,,,
--- --- --- --- WITH NO TAKERS,,,
(CRAZY,,, considering that once this is discovered to be real, every government in this world)
(will pass laws, mandating that this tech is used + not oil burning engines,,, which funds terrorist)
1 rotation of a 100 cm circumference pulley will give you 100 rotations for as many of the # of
1 cm circumference pulleys attached + with adding simple generators to these 1 cm mini-pulleys,
you can be multiplying your # of AC cycles/units of electricity
---  All through what seemingly legally breaks the laws of thermodynamics
--- ---  by using simple pulley mechanics, that we learn in grade school
--- --- --- to actually multiply our AC electricity - (instead of paying for oil to generate it)
YES, through pulley mechanics, you can trade one revolution of a 100 cm circumference pulley,
--- into 100 rotations of a 1 cm circumference pulley, (for every 1 cm mini-pulley you add to belt)
--- --- so if added 10 mini-pulleys, you would get a return of 10X100=1000 cycles of AC electricity
THAT'S ONE ROTATION OF A DC MOTOR BEING MULTIPLIED
--- INTO 100 ROTATIONS OF AN AC GENERATOR
It's as simple as using the laws of pulley mechanics to multiply our AC electricity, by paying for one rotation of a 100 cm circumference pulley, and gaining a return of 100 units/cycles of AC electricity.
WHY CAN YOU NOT SEE THE BASIC SIMPLICITY OF,
THIS USE OF PULLEYS TO MULTIPLY AC ELECTRICITY.
This is a way of seemingly legally breaking the laws of thermodynamics
By using simple pulley mechanics to multiply your rotations = AC electricity
remember, I have already had one man build 3 different models,,,
but he is worried about the rumors of people disappearing,
I mean those who had actually built working models
the Book that I put all of my faith in is the Word of God
+ if you want to see how the Holy Bible can prove itself God inspired
you should read a novel  called "Armageddon" by a Canadian author named Grant Jeffrey
which proved to me that the KJV Holly Bible was truly Written by God
He did this by systematically going through fulfilled Bible Prophecies,
and showed how they were fulfilled right down to the exact day
+ Who else but God, could consistently predict the future
it was one of the rules with God, the one about how He gave a second chance to Israel
after 10 times the original duration
As in, when you take 10 times the original duration, of the prophecy about when Jesus would enter Jerusalem, you get a second chance for Israel. I don't know about you, but I happen to be quite the skeptic, and thought that maybe the reasons that these prophecies worked out so perfect, was that they were written or changed after they were fulfilled. But this one about Jesus entering Jerusalem on the exact day, + when you take 10 times the original duration, of the time between when it was prophesized + when it was fulfilled, you get may 14th 1948, when the nation of Israel was reborn. http://www.grantjeffrey.com/pdf/JeffBIBLE-EzekVision2.pdf
<<< EVil-sOLUTION >>> (isn't it amazing what is revealed by the il-s of life)
http://decimationofthisevolutionfairytale.yolasite.com/
THIS IS GOD'S GIFT TO THE SOON COMING TRIBULATION SAINTS
http://free-energy.yolasite.com/
Because the Door will close on this Prophecy being fulfilled on Jan 15th , 2019
http://doorschristmustpassthrough.yolasite.com/, http://2020-vision.yolasite.com/
These are the rules God has set before us
http://beliefstoliveby.yolasite.com/
possible timing for TRIBULATION SAINTS
http://possibletimingfortribulation.yolasite.com/
UFOs + GHOSTS do exist, there are just not who they pretend to be
http://aliensandghosts.yolasite.com/
It was how God predicted, to the exact day,,, May 14th, 1948
the day that Israel would get their second chance + become a nation again
Written in the Holy Bible way back in Ezekiel's day
This convinced me that the Holy Bible spoke Truth
About Jesus Christ paying for our Salvation
+ Jesus being the only Door for us to enter Heaven
Becoming a part of God's Family
that_prophet
 Free energy in UFO motor, described  in the Bible
+ multiplying AC electricity with multiples of both size and #'s of pulleys
= https://free-energy.yolasite.com/
- this is so super simple,
that we should be ashamed of allowing satan
+ his fellow evil spirits, to have kept it hidden
for so long = ever since Ezekiel 1:16
- "a wheel in the middle of a wheel",
where it was the first simplistic described how a UFO motor worked in the Holy Bible,.
You only pay one small bit of DC current
to rotate 100 cm circumference pulley one single time,,,,
+ through running the 100 cm of moving belt,
(which came off the circumference of pulley)
+ running it by 10 of the mini- 1cm circumference pulleys
+ attaching AC generators to each pulley,
you can multiply your AC electricity to 10X100=1000 cycles of AC electricity
,,,,,,,,,,,,,,,,,,,,,,,, all for the cost of one spark of DC current
=(just enough to rotate your DC motor one single time)  .  .  .   .  .  .  .  .  .  .  .  .  .  .  .  .  .  .   .  .  .  .
<<< NOW TRY + TELL ME THAT YOU CANNOT GET ENOUGH VOLTAGE FROM THESE 1000 CYCLES OF AC ELECTRICITY,,, + ONLY THE ONE SPARK OF CURRENT, THAT IT TAKES TO ROTATE YOUR DC MOTOR ONE SINGLE TIME >>>
(I hope this makes you realize reality, + how powerful spiritual warfare is going on all around you every day)
YES,,, GOD IS REALITY,,, + HE IS COMING BACK BEFORE 2019.04=Door –(in air for all born-again who are looking for His Coming)
although we are warned that "of that day and hour knoweth no man"-Mat 24:36,
we are also told that we can "know that it is near, even at the doors"-Mat 24:33
Just think of it this way, you are only putting in one small bit of DC current,
Enough to crank over your DC motor once, with a 100 cm circumference pulley attached,
+ through simple pre-school  pulley mechanics, of running this 100 cm of moving belt,
that comes off the one rotation of your 100 cm circumference pulley,
Past 10 mini-pulleys of 1 cm circumference, with free running AC motors/generators attached,
+ you will get 10 X 100 = 1000 cycles of AC electricity.
All for the cost of DC current to rotate your DC motor one single time = only one spark
http://my2020vision.yolasite.com/
http://evotutionfairytale.yolasite.com/
