Silly question about capacitors
Started by dieter, February 14, 2014, 10:48:52 AM
0 Members and 23 Guests are viewing this topic.
forest
what about the change of two charged capacitor connection from parallel to series ? how law of conservation of charge apply to that situation ?
dieter
But Resistance in series adds up to more resistance and therefor more loss, isn't it?
I'm back at square one, heat dissipation is no explanation to me. If there was really more "pressure" in the 8 to 16 volts, then the 2 caps simply should be equalized at 16- ((sqr(16)/2)^2)=12 volts. Because the electricity does not jump across the room and run away, nor have I ever seen a cap getting excessively hot simply by charging and uncharging it within its supposed specs.
You may call me silly , hence silly questions, but the paradoxon is yet unexplained to me. I'd rather see there are many paradoxons in established sience that are always "talked to death" in the sense of "science knows everything". No offence tho. Maybe I'm just not getting it.
dieter
forest, actually the initial experiment is in series, even a loop in series. Of course, the cap must have polarity, like electrolytics do have, otherwise it would be parallel and serial in the same time. (in this little 2 caps experiment
Or did I misunderstand your question?
MarkE
Quote from: forest on February 16, 2014, 04:09:53 AM
Charging up one capacitor with capacitance C and then connecting it in series with another discharged capacitor with the same capacitance C has the same effect on energy loss as the situation in the OP.  And as Dieter pointed-out once the switch is closed the two parallel capacitors are in series in the loop.
MarkE
Quote from: dieter on February 16, 2014, 04:16:32 AM
What increasing the resistance does is increase the amount of time that it takes to transfer the charge.  It does not change the percentage of energy lost transferring the charge.
If you want to see capacitors get hot doing this we can set up an experiment that will heat them nicely by choice of capacitor and the test circuit.  Ceramic and film capacitors can handle very high ripple currents. Electrolytic and double layer capacitors are a different story.  Ripple current ratings and limiting internal heating of electrolytic capacitors is an important aspect of power converter design in converters that use electrolytics.
