Work from 2 magnets > 19% output 2
Started by Floor, February 17, 2014, 01:53:56 PM
Floor
        Personal Message
from Lumen to floor
Re: (No subject)
Sent to: Floor on: Today at 06:19:07 AM »
(in part)
"Hi floor,
At this time I remain somewhat skeptical even though the testing I have done appears to indicate some energy gain in the results.
I have been delayed from further testing by other tasks......"
   thanks Lumen
              floor
Floor
Please find the attached file below "TheMatrixHasYourNeos" PDF
             Cheers
Floor
               SIMPLIFIED
                   Please find the attached file "PassThru 5. PDF"
Floor
PLease find below, a fix for the "PassThru 5" PDF.
            floor
norman6538
Floor could you describe your pass thru setup step by step? In the past I have many times gotten past the sticky spot but then when you take power off of a balanced system you are then stuck with not being able to reset and repeat the cycle. Permanent magnet power source would be easy if it were not for the reset/repeat sticky spot.
Norman
