Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
0 Members and 23 Guests are viewing this topic.
HG8AD
magpwr
hi verpies,
I have reverse engineered the pulsed flasher at pin 8 IC Section MC14063.
Please assist to verify and update the previously attached circuit.Thanks.
Please take note i have made a small mistake the trim Pot with 103 marking is actually 10K Ohms instead of 1K Ohms.There are 2 "103" pots in circuit.
The only thing i do not know
1)the tiny capacitor value found on pin3 & pin 4 of MC34063.I assume it's 510pf base on other replicate diagram.
2)There are just 4 wiring to ferrite pot core which i do not know from left side of ferrite pot  is connected to which one on the right side of circuit.
    At this moment i simply assume after diode which is connected to (+)1000uf 10volt from pin1(MC14063) will eventually lead to transistor collector at the other side of circuit.
    This makes the most sense for me.
3)Resistor value between pin 7 & pin 8 can be faintly seen as 2 red which i assume is 220 ohms.The other replicate shown as 180 ohms.
4)Resistor beside 10k ohms pot near 8 pin IC looks like 1.2KOhms brown,red,red,gold.
Only those with "oscilloscope" would able to see if the trigger is happening at which position of waveform."This is important".
5)I did not put the kill push button which is not important as short circuiting the caps would cease oscillation if this device works as "FE" device. :D
6)Latest update -I can't tell if the pin 4 of MC34063 is indeed connected to ground(-).Base on datasheet it's conected to ground.
     Pin 6 (MC34063) is where + 3volt power needs to be applied during testing stage/before self run.
The  CD4069 trigger frequency should follow with the oscillation frequency of MC34063 since i don't know the tiny cap value used.
I will have a go at this circuit once i received the ferrite pot and 8 pin ic. ;)
Not forgetting the counter poise beneath ferrite pot which is the large copper track which is also the (-)
I'm sure now the creator of this device would be mad at me. :D :D :D :D :D :'(
For those whom just read my recent posting with verpies-
This is the video which i have reverse engineered circuit merely by looking at youtube video.Less than 1 watt free energy device.
http://www.youtube.com/watch?v=juwm_W5-qAM
http://www.youtube.com/watch?v=gWjs0-WCMzs
4Tesla
@magpwr
Nice work!   8) You should start a new thread for this project.  I will follow.
verpies
Quote from: magpwr on April 12, 2014, 09:18:58 AM
I have reverse engineered the pulsed flasher at pin 8 IC Section MC34063.
Is this what you had in mind?
