Breaking the Lenz´s law
Started by policiarj2, March 21, 2014, 09:32:46 AM
policiarj2
Hi, I read in this forum about some person that said to get free energy we must cancell the Lenz´s law (Referring to the Thane Heins transformer does it), and he really has reason, well I put my idea, if someone has other ideas, go ahead, don't be shy, laws are made ​​to be broken.  Also I put this video about the Lenz´s law, I dont know why the magnet is moved too fast when it goes through the pvc coil, where is the Lenz law there?
https://www.youtube.com/watch?v=JN-A3RryOC8
Neo-X
I cant watch the video, can you post a screenshot?
MarkE
The scheme does not work.  First:  Lenz' Law is often confused with Faraday's Law of Induction.  Lenz' Law simply states the direction under Faraday induction.  Most attempts to "cancel" induction that I have ever seen amount to connecting what amount to two coils together each subject to the same magnitude induction head to tail.  What this does is reduce the external voltage to small values.  The induced current runs through the internal impedance of the coils heating them up.  The external connections do not get rid of or cancel the induction.  They convert the energy imparted into heat.  Commercial machines called eddy current brakes do this on purpose.
Neo-X
There is only one way to cancel the lenz law it is add a second coil that would cancel the magnetic field of the first coil.
crazycut06
Hi Neo-X,
If you do that there will be no output, magnetic flux will cancell out.
