0 Members and 55 Guests are viewing this topic.
PCB
Kevin I hope you are still looking in and reading some of the stuff being posted here. Much of this was covered in detail many months ago. James R. grossly miss measured the power output of  the QEG in the beginning, and made numerous wild claims. This group pointed this out to him and the rest of his team that his measurements were totally wrong. They then changed their OU claims to power measured in VARs (reactive or imaginary power), which HopeGirl heralded front and center in a fund raiser prior to going to the UK. This was complete nonsense of coarse, as all James was doing was measuring the stored energy in the primary tank circuit, which he had to limit using a spark gap to prevent damage to the core.
TK's point about the phase shift introduced by the current measuring transformer is critically important. They most often introduce a 90 degree phase shift, making you think you are measuring real power (W) when you are really measuring reactive power (VARS).
Lastly, there is no doubt that James R. tried to steal electricity from broadcast stations. Here is a little piece I found on this from the UK that discusses this, and I'm sure the same laws apply in the US:
Re: And is illegal in the UK
"As in the celebrated case of a a farmer using fluorescent tubes with some wire attached to the ends to light his cowshed. He was in the near field of a some large (IIRC BBC) transmitter."
You're right but I was told during a lecture that it was in the U.S. and it was signals from the ultra long wave submarine service (in the 10s of kHz). Perhaps, that's just another case.
Anyway, the net result was that it's considered stealing electricity (by longstanding case law). Seriously, this is a potential problem:
(a) with enough RX antennas absorbing energy, the effective service area will be reduced, and;
(b) increasing the TX power to overcome the increased 'absorption' will lead to excessive and necessary power levels, which, in the extreme, will increase the radio spectrum noise floor. (Increasing noise floor in spectrum management is already a significant issue.)
This getting-power-for-nothing idea has been around for some considerable time. Except for induction charging batteries (a la electric toothbrushes etc.) it's not been very effective. Always guaranteeing sufficient Volts/m to power devices is a problem as signal strength can fluctuate wildly. Whilst signal strength fluctuations are unlikely to cause problems to the the RF link (with AGC, limiting etc.), that cannot be said for devices which have to absorb power from surrounding RF to work.
These devices aren't absorbing low frequency stuff, rather UHF (from the antennas). UHF, of course, is much more prone to nodes and anti-nodes thus more unpredictable/unreliable than the ultra low freq. case to which I referred.
The whole tread is here: http://forums.theregister.co.uk/forum/1/2013/08/14/boffins_hawk_powerless_radio/#c_1925349
PCB
Kevin, the last pictures of James R. in August showed him erecting Antennas outside his recently foreclosed property in PA. This was a Hail Mary attempt to show OU in his latest QEG build. Given that this was the track he was on, and his previously stated effort to tune the QEG to 1.3Mhz, and with no further information coming from him, and you working behind closed doors with your many degreed and experienced electrical and electronic engineers, I have to assume that you intend to go down the same path. Therefore, I need to point out.  that while possible, stealing electricity from broadcasters is strictly illegal, so I would encourage those publicly minded individuals with a conscience to email the Canadian Radio-television and Telecommunications Commission  http://www.crtc.gc.ca/ of your intent.
PCB
200. Kevin, you should look at the level of activity here on overunity.com http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/6240/#.VFA3LPldUzo as to what you might expect if you and your team were willing to share correspondence. I very much doubt that things are this intense behind your closed Skype door. Moreover, like be-do, the people who are contributing in your technical Skype forum are not likely to be real engineers with experience but more likely sycophantic "engineering artists".  If you really believe that there is some real science behind the QEG then you would wish to open up the dialog. There are many people here that really do want to make a positive contribution, but they also can smell bullshit and fraudsters a mile away!
Pirate88179
Quote from: PCB on October 28, 2014, 03:20:05 PM
Lastly, there is no doubt that James R. tried to steal electricity from broadcast stations. Here is a little piece I found on this from the UK that discusses this, and I'm sure the same laws apply in the US:The whole tread is here: http://forums.theregister.co.uk/forum/1/2013/08/14/boffins_hawk_powerless_radio/#c_1925349
PCB:
I find your points about radios stations very interesting.  I have always contended, in many arguments here over the years, that a radio station that puts out say 50,000 watts has no idea if one radio is tuned in or 10,000 radios are tuned in.  I have also contended that if 20,000 folks tune in, the station does not have to up their power to continue being heard.
Of course, this was dealing with simply lighting a few leds from an antenna set-up and nothing that would "block" or "absorb" large areas of broadcast projections.  I was always taught that once those broadcast waves left the antenna and spanned outward, it did not matter if they went out into space unlistened to, or were heard by everyone in the area.  This is the first I have heard that I may indeed be wrong about this.  I will need to look into this further.  I appreciate your mentioning this as I hate have to have wrong assumptions floating around in my brain.
I agree with all of your thoughts in your posts reguarding the QEG.
ACG
Appreciate your efforts.  But I am afraid the strain of truth is more than truthseeker could bear.
