Quantum Energy Generator (QEG) Open Sourced (by HopeGirl)
Started by madddann, March 26, 2014, 09:42:27 PM
F_Brown:
QuotePeople often seem to have trouble understanding the nature of resonance and tank circuits.   More specifically how voltages and currents can rise numerous orders of magnitude within tank circuits as resonance is approached and how tanks circuits can store a surprising about of energy once in resonance, which can then be drawn off in small portions while the system remains in continuous operation.  The fact remains though, that one has to put energy in before one can take it out, and one can only take out as much as was put in minus resistive losses.
You are absolutely right.  When you think of the child on the swing example, the swing will swing high enough so that the amount of energy you supply with each push is equal to the amount of energy that is burnt off with the air friction.  So in addition to the in-out equation that you reference above, the sobering thought is that the electrically resonant circuit will climb in voltage in proportion to how much power you are able to put into it.  So depending on how you do your excitation, it's possible for a very impressive very high resonant voltage to actually represent a significant burn off of the supplied power.
That suggests a measurement:  When the QEG is resonating at a very high voltage without being connected to a load, how much power burn-off does that represent?  You can measure the DC resistance of your coil or coils, so you are poised to make that extremely important measurement.
F_Brown
Quote from: MileHigh on April 16, 2014, 09:04:36 PM
Yes.  I've been reflecting on the insulation breakdown in Taiwan.  A repeat of that could be avoided by adding some additional resistance in the HV primary circuit to limit current and dissipate some energy, or the gap of the spark gap could be reduced to limit the HV in the primary by another method.   Building up insulation around the core is sound, although limiting voltages and currents to known safe levels is always good practice too.
jbignes5
Read this ok High boy....
http://borderlandresearch.com/book/secrets-cold-war-tech/chapter-1
Read it all then re read it a few more times. Impulse technology does not conform to your Laws. But then again why would you know anything about it at all? If you can't read then maybe you can get it in preread recording.. Learn something new ok...
jbignes5
Quote from: F_Brown on April 16, 2014, 09:14:10 PM
They opted for insulating wraps in between layers.
SeaMonkey
With the QEG resonance is a narrow band of frequencies
because of the cyclical changes in inductance as the
rotor rotates.  It is being pumped.
What is the relationship between the resonant band
of the device and the rotor rate of magnetic reversals?
Or, should we say, what is the desired relationship?
