Quantum Energy Generator (QEG) Open Sourced (by HopeGirl)
Started by madddann, March 26, 2014, 09:42:27 PM
Quote from: F_Brown on May 11, 2014, 07:40:21 PM
The QEG has an odd behavior of maintaining a somewhat constant current into resistive loads.  In simulation I have noticed that to get more power dissipated in a resistive load, I had to to increase the resistance of the load rather than decrease it.
So, I would recommend putting bulbs in series rather than parallel and see what happens.
Indeed the 'odd behavior' is exactly how a discharging inductor behaves.  In the real QEG if the simulation is accurate it would suggest that the spinning rotor induces magnetic energy into the core because it is exciting the primary.  That causes Lenz drag on the rotor.  Then when the rotor is out of contact with the core the magnetic energy in the core has to go somewhere, and the exit path is through the secondary into the light bulb load.  I will repeat that all of this would have to be confirmed on the real QEG by doing a detailed timing analysis.
The above behaviour describes a transformer operating in pulse mode, i.e.; somewhat akin to an ignition coil.  That's opposed to AC coupling where the primary and secondary transfer power simultaneously like a set of meshed gears.  Since it is unusual in design, it may have properties of both.
That ties in directly to the subject of the light bulb load.  Do you connect the light bulbs in series or do you connect them in parallel to put a heavier load on the QEG and have it transfer more power into the load?  The answer to that is not determined and tests would have to be made.  It's a huge mistake for an experimenter with this setup to "know" head of time one way or the other.  The first step is to measure the resistance of the secondary coils.
Big update from James:
http://be-do.com/index.php/en/forum/qeg-news/366-morocco-qeg-build-general-progress-update-part-1#1533
Hi everyone! We've not had internet for the past couple of days since I promised an update. Here it is from Jamie:
Morocco QEG Build – General Progress Update – Part 1                                           10-May-2014
To: All our Amazing Supporters and Followers
As I'm sure everyone is aware, we have had many engineers and technicians here in Morocco working on the QEG with us in the last 3 weeks. Of particular note are the guys from Germany and the German speaking countries, Holland, UK, Canada, and Slovenia. Thanks to these dedicated individuals for their time, effort, and support, spiritually as well as technically... And thanks also to all the amazing and selfless people who brought us parts for the QEG in their suitcases and carry-ons without regard for risk involved. All have contributed to this endeavor, and all are greatly appreciated!
I must personally apologize to all for not publishing more material and more of my own comments on progress etc., to date. It has been a struggle to keep the build and the development process moving forward due mostly to difficulty sourcing parts here, and researching design questions. There has been little choice but to just keep working and try to catch up with your questions, comments and communication whenever internet/phone are available (which is only about 3% of the time in Aouchtam). The engineers and residents here have just made some improvements with the internet hardware, so we're expecting communications to be a bit better now going forward. And hopefully this update will clear up most of the technical concerns and lack of documentation.
I'm sure the question in everyone's mind is: How close are we to overunity? Well, here in Morocco, we are very close, within about 200 Watts (800 Watts out for 1000 Watts in at this point in development). We have heard yesterday and today that (2) other groups have completed the basic QEG build, and have resonance. This is good news, since the more people we have working on the development, the faster we will reach our goal.
In the last few days, several negative posts and comments have been circulating about what we are doing here. This is astonishing to us! Apparently some groups and individuals were expecting a completely finished product to be delivered into their hands, with nothing left to do. We have always said that as soon as we got the basic resonance from the machine, we would open source all the information we had, and that's what we've done. The intent was to co-develop the machine in an open source platform, with input, comments, test data, solutions and suggestions shared transparently between all groups that have chosen to build the machine.
Continuing in that spirit, here is a snapshot of our current status...
As we've said before, after the mechanical build, it's not too difficult to get the machine into resonance, since it is a variable frequency generator. We were instructed (by WITTS) to 'match' the electrical resonance ('tank' circuit resonant frequency), with the mechanical resonance (self-resonant frequency of the steel core) which was stated to be around 400 Hz. It was also stated that type M21 steel should be used for the core (however, M21 has been obsolete for many years), and that type M19 could also be used, but the resonant frequency would be lower. It was stated that a 'harmonic' could be used, such as 200 Hz, and that would work also. We decided to look for a peak power point (fundamental resonant frequency) between 1733 RPM (116 Hz output frequency) and 3008 RPM (200 Hz output), as this seemed a reasonable speed range for the mechanical setup (Witts' machine is running about 2450 RPM in the latest video).
We arranged a test using small increments of capacitance (about 7 nF each) starting at the low RPM end (about 1733 RPM, with C of 332 nF). We did 45 iterations, in order of increasing frequency, with the input power fixed at 700 watts. The target was to plot output power against input power to try to develop a bell curve showing a peak resonant frequency. After 43 iterations, we went back to the first C/RPM value to verify it had not changed, and added one more iteration at an extra-low frequency (1727 Hz = 115Hz output frequency). We also did one shot with the input power fixed at 900 Watts (see attached tabbed spreadsheet "QEG Resonance Plot.xlsx").
As can be seen from the data, the expected trend did not really emerge from this test. The curve is quite flat (no curve) in the targeted speed range, and there is no obvious increase in power. The extreme low RPM end has the best power output and phase lock effect, which also seems to increase linearly as frequency is reduced. However this result doesn't really fit with the mechanical setup (machine is running too slow) or with expectations from the WITTS instructions.   We are currently testing at 3000 RPM (200 Hz) and above, to determine whether or not there is a peak power point in this range (which seems too fast).
It's possible the 7nF steps we used were too large, but not likely that the peak resonant point would be that sharp. If we do not find a peak in the range of 200 Hz and above, we will assume that the exciter coil must be in place and operational to be able to find the 'sweet spot' in tuning the capacitors to the core resonance. We are determined to document and publish the technique necessary to do this 'etheric' tuning.
We have also heard from others who have taken the WITTS classes, that an antenna of 20 to 50 feet in length, along with the earth ground(s), are important to bring energy in from the environment, and that the exciter coil can be connected in the primary circuit or the secondary circuit. We will try all possible combinations of these connections, and report our findings in Part 2 of this update.
We are having some preliminary success with the exciter coil wired in series with the primary, at a nominal RPM/C value of 2700/140nF. The output is loaded with 6 100 Watt, 240V incandescent lamps, wired in series to provide a relatively light load, but allowing the output voltage to rise as high as 1440 volts (240 Volts X 6). While adjusting the rotor speed to provide about 500 Volts output, we have a small spark in the gap. We have been able to tickle the spark gap and keep a small arc going for several seconds at a time.
We will continue with testing for a max resonance point in the speed range of 200 Hz and above, and also with examining exciter coil effects on power output. We will provide results and analysis of testing in Part 2 of this update, in a few days.
We are very grateful to 3 of our UK guys who have provided a complete array of test equipment, delivered personally last night here in Morocco. This will be invaluable to us for ongoing development, and to publish readings and results.
(Also attaching the update word document here and the QEG Resonance Plot excel spreadsheet.)
Stay 'tuned' for more...
Much Love and Light!
Jamie
What James has to say is not confidence inspiring.
Here is a smoking gun and people should be very concerned:
QuoteIn the last few days, several negative posts and comments have been circulating about what we are doing here. This is astonishing to us! Apparently some groups and individuals were expecting a completely finished product to be delivered into their hands, with nothing left to do. We have always said that as soon as we got the basic resonance from the machine, we would open source all the information we had, and that's what we've done. The intent was to co-develop the machine in an open source platform, with input, comments, test data, solutions and suggestions shared transparently between all groups that have chosen to build the machine.
Straight from the HopeGirl blog:
http://hopegirl2012.wordpress.com/2014/03/25/qeg-open-sourced/
QuoteAs Promised, here are the open sourced documents for a quantum energy generator. This has been made possible by the people and for the people. It is freely given to the world.
An average modern household requires 5-10KW of power  to operate.
A conventional generator needs   15KW to produce 10KW of power.
To produce these 15KW of power we rely on gas, diesel, propane, coal or other products that can be metered creating profits for the oil industry.
130 years ago Nikola Tesla invented and patented an energy generator. This is a resonance machine that only needs 1KW of input power to produce 10KW of output power.  His patents are now in the public domain.
The Fix the World Organization has reproduced Teslas design with a few modern twists to generate the same results.   Our Quantum Energy Generator (QEG) provides 10KW of power output for less than 1KW input, which it supplies to itself.
We have freely given this technology to the people of the world.  We've open sourced a full set of instructions, user manual, schematics and parts list for any engineer to follow and reproduce the same results.
So they are caught in a lie, and presumably hundreds of thousands of dollars have already been spent by many people.
chrisC
Quote from: MileHigh on May 11, 2014, 08:35:13 PM
@MH
Never thought that you will be that anxious or quick to re-post such 'nonsense'. Maybe the fact that they are only 200W from O.U made you wet your pants? Well, just sit tight and wait. Hopefully you won't crap in your pants if and when they are able to achieve their goal.
cheers,
chrisC
ChrisC,
Thanks for the classy metaphors.
There are two docs that go with James' posting but I can't read them on my home computer.
However, here is comment from somewhere else about the documents:
QuoteHaving looked through Robitaille's report more in detail here's the next irritating issue: His table with measurements doesn't even remotely match his claim of having achieved 80% (1000 W in / 800 W out) efficiency. The results in the table hover around 700 W in / 250 W out, or roughly 35%, with the best result around 700 W in / 308 W out, or 44%. Why always these incongruencies?
And there's still no info how *exactly* he measured output power. Given how problematic AC power measurements can be (phase shift and all) that doesn't inspire confidence in his measurements.
