3v OU Flashlight
Started by 4Tesla, April 14, 2014, 02:55:28 PM
lost_bro
Quote from: JohnnBlade on May 01, 2014, 10:09:34 PM
@Lost Bro,
Thnx man, it worked!
Since i was busy i did another core, but not knowing that when i placed the 2e core into the boiling water it cracked into 4 pieces :)  so it was a good lesson not to dump a core into boiling water :)
Good shit Lost Bro!
Now lets try some Akula stuff ; )
Greets JB
Good day JohnnBlade
Super glue it!!!   The core will still work, maybe the permeability is off, but still works just fine.....
take care, peace
lost_bro
lost_bro
Quote from: dewetw on May 02, 2014, 04:48:29 AM
Could all this be just coincidental?
More about nickel. Nickel is one of only 4 known ferromagnetic elements at room temperature. Iron(Fe), cobalt(Co) and gadolinium(Gd) being the other 3. Note: manganese(Mn) is not one of them. Why have a core based on manganese (MnZn) then and expect it to interact with an magnetic field in the same way as nickel based (NiZn) one? The QEG is based on a specific steel alloy (M19 C5, aka electrical steel) core, an alloy containing both iron(Fe). If you do not use the correct core material in the QEG it does not work. If the QEG does not go into resonance, it does not produce extra energy out. The QEG "builds up and goes into resonance". NAR? NMR? Both maybe?
I believe that what we are trying to achieve and what is being done by the QEG is the same - this is great news.
Also think about this: the bedini device only produces OU sometimes. It has been reported that the weaker ferrous magnets produce better results than neodymium magnets. Could it be because the neodymium is not one of the 4 ferro elements? - I'll investigate this further. Here too we see aligned electron spin and controlled magnetic fields.
What Akula is doing, what bedini is doing and what is claimed in the QEG just have too many coincidences to ignore. Lets use this to our advantage: find the commonalities, derive theories, test and eliminate to move forward. There is a some more interesting things to note about nickel I will communicate at a later stage.
The capetonian
And lets not forget about Stanley Meyer with his famous Stainless Steel tubeset and his 5-coil Vic set up which boasted a complex interaction between *distributed*  COIL capacitance and an elusive inductance value..............
In the end even S.M. went to lengths to analyse the composition of his *original* tubeset, because even he was *not* sure of the chemical composition or processing that made his system function.
It was *speculated* that he purchased the *original* S.S. tube material from a metal scrap yard, and did *NOT* know the actual composition or *processing* used in his original tubeset.
Now rethinking along the lines presented, it could be possible that some industrial process was used on that original S.M. steel, and that that is the *trick* to making it work!!!
Yes, think outside the box.........
take care, peace
lost_bro
tysb3
@ lost_bro
and people on Stanley Meyer don't know what is purpose of HF generator. I think it is for the steal plates atomic resonance, like Akula's device.
lost_bro
Quote from: tysb3 on May 02, 2014, 10:42:31 AM
@ lost_bro
Good day tysb3
Yes, exactly my point,  I do *not* believe it to be coincidence and it would *not* surprise me the least to find out that the M.O. for these devices are related............
take care, peace
lost_bro
tysb3
the ferro resonance could be free energy pump from the "zero point" energy.
