3v OU Flashlight
Started by 4Tesla, April 14, 2014, 02:55:28 PM
0 Members and 18 Guests are viewing this topic.
Quote from: semenihin-77 on May 24, 2014, 07:08:20 AM
http://www.youtube.com/watch?v=aY9_Cjt4Mqc      :)
When your PSU is showing the higher voltage and zero current.... please then vary the output amplitude of the Function Generator to see if this PSU-indicated voltage changes.
http://www.youtube.com/watch?v=x7ohH9ruspE
Quote from: T-1000 on May 24, 2014, 07:15:14 AM
Just place capacitor after diode and attach analog milliampmeter to show power consumption as your PS amp meter is not that sensitive for mili/micro amps draw ;)
The meters on the Power Supply should _never_ be used to make quantitative calculations or claims. They are just there so you can set the PSU easily. You should always use separate meters connected properly to your DUT to make quantitative measurements. As I've shown the voltage indication may be subject to false indications due to the circuit's voltage actually supplying more than the PSU is set for (and other reasons), and as you note the current indication is only good to two significant digits and is only approximate.
semenihin-77
Quote from: semenihin-77 on May 24, 2014, 09:09:21 AM
Вот так использую конфликт токов получил уже что то в резонансе.
http://www.youtube.com/watch?v=1TIkoCZSnEk
Google translates that as:
Quotehere so use current conflict has already received something in the resonance.
Which isn't any language I understand.
The purpose of communication is to transfer information effectively, isn't it? This forum has sections in French, but mostly it is conducted in English, even though it is based in Germany and our host is German.  If you want to start a Russian section, you can probably do that easily enough. I won't be reading there, so that might be seen as a benefit to you.
T-1000
Quote from: TinselKoala on May 24, 2014, 09:16:22 AM
"Вот так использую конфликт токов получил уже что то в резонансе.[/size]
http://www.youtube.com/watch?v=1TIkoCZSnEk[/font][/size]"
"So I am using conflict of currents(EMF against BEMF) and got something in resonance"
Obviously you cannot push Russians to speak proper English when it comes to specific terms and Russian experimenter with fluent English is rare find ;)
