3v OU Flashlight
Started by 4Tesla, April 14, 2014, 02:55:28 PM
rakarskiy
Quote from: Sergh on September 06, 2019, 08:15:22 AM
High permeability - and what's the point?
Metglas alloy has even higher permeability than ultrapure iron, and low losses. Transformers on such cores don't produce free energy.
https://web.archive.org/web/20120206100947/http://www.metglas.com/products/page5_1_2_6.htm
No point arguing, "everyone has a right to their own rake"! FORMULA OF MAGNETIC INDUCTION FOR THE CORE OF THE SOLENOID: Only (Mu0) need to write like (Mu * Mu0)
Where
       N- is the number of turns of the solenoid
       l - long solenoid
      n - number of turns per unit length
      I - Current in the solenoid
       Mu - magnetic permeability of the medium inside the solenoid
      Mu0 - magnetic constant
  Mu - (magnetic permeability of the medium inside the solenoid)  Just enter 1/10 of the value of 20,000, get 2,000 and enter the formula for the core 30 mm long. Divide the resulting value by 2 and substitute it into another formula. which I designated in the description on the diagram. For a frequency of 5 kHz (conversion to speed, I hope you know how, iron does not like high frequency).
The closer you place the L1 winding to the core at the ends, the better. In general, study all the materials about Tesla transformers, there is nothing new here.
The shows, with the help of this scheme, from different authors, are gaining momentum. Did they know how to make a show, put it together in plain sight, put it to work??? and run and run differently .
https://www.youtube.com/watch?time_continue=399&v=qCi2-6kAkqA
Reiyuki
Quote from: Raycathode on September 06, 2019, 04:10:22 AM
Explain where the Extra energy is coming from!
all I can see is losses with your set up, exp;lain your coil winding and how you encounter the effects of skin effect, Also with the flywheel energy will be lost with spin up and down inertia ect and friction ect, etcetera and then there is lens laws ect, you were saying about gutters and bodily fluids ect, well drink your poison of your own choice and be merry as you do.
Raymondo
If I understand the process correctly;
By modulating the inductance of the core (as in a Magnetic Amplifier / Saturable Reactor), one can create a hysteresis loop that is inverted in a portion of the cycle.  This inverted region has a mathematically negative inductance and depending on the phase-angle might be used to explain the excess energy (or energy destruction).  Normal normal core/electric/hysteresis losses of course still in effect, so a system that employs such a modulation is not automatically COP>1.
  The closest analogy would be throwing a baseball from a moving car vs standing on the ground.  When throwing a baseball forward while the car is moving forward, the velocities of both systems are added.   Due to the nature of a mag-amp, a similar act can be done in a predominantly one-way action (since the modulation/control winding of such a transformer is not significantly affected by the load winding).
The reason high-permeability cores tend to be used in such systems is because it allows larger changes in inductance per-unit time.  Parametric variation of inductance.
A modern circuit simulator that can handle parametric variations of L or C should be able to demonstrate these same nonlinear effects, but Steinmetz/Dollard mathematics can also be used to gain a more classical understanding. ;)
I suspect the Russian tinkerers have a hard time articulating these concepts themselves due to the language barrier.
Anyway, I hope that explanation is concise enough to make sense. :)
Further references:
http://www.tuks.nl/pdf/Reference_Material/Steinmetz/Reaction%20Machines%20chapter%20in%20Alternating%20Current%20Phenomona.pdf
https://youtu.be/DBX1-POuJMw?t=76
http://www.tuks.nl/wiki/index.php/Main/EnergeticFormPosts
rakarskiy
You did not realize that in the scheme I proposed, there is no change in the magnetization of the nucleus in the classical sense at all. The nucleus may even remain at a certain level of magnetization. Only to remove more, you need another combination or item (not listed in the diagram). After all, energy is a more commercial term, an engineer is interested in forces, potentials and their combinations. Sincerely, good luck to you all!
ARMCORTEX
As I suspected, this russian guy trolls people because he knows that everything has to be just right with the core and you have 0.01% chance of making it work.
Whats to say there is not a magnetic core conspiracy and basically we would need to make one ourselves? I read this before, it makes sense.
Make the scheme, with all possible core that you can buy online and see if it works, then we will know if this conspiracy is true.
Put 400$ of core, wind for 40 hours of coils. And you will have known all permutations allowable to you.
My opinion of this: too annoying for the amount of wattage provided.
rakarskiy
Quote from: ARMCORTEX on September 06, 2019, 12:01:28 PM
Honey, if you're accusing, you must have a good reason!  I wonder what reason you have? Your worldview is probably different from mine. But that doesn't change the facts. Any core of soft magnetic material increases the electrical voltage of the coil (winding) in the magnetic field of the core, N times.  Here's how to use the question I just suggested. This scheme forces spectacle to remain, but not forever.
