New!! V-gate Double Coil System (DCS)
Started by overunity7, April 20, 2014, 09:44:28 AM
overunity7
hi, I introduce you the new V-gate Double Coil System (DCS) this is a new system which is designed to improve the result of success of the actual V-gates, to understand the system you must pay attention in the below photo and look in the placement of the coils and the rotor because it is the key.
I guess with a device properly built it can run itself but the start will be by hand, I am not sure if it needs some capacitor or diode between the coils, but if it does not work itself, always we can  make an adjustment and integrate the circuit of Bedini in the double coil system, that is the good thing in fact the efficient will be too much higher than the actual Bedini motors.
dieter
Hi,
could you explain a little more the principle? For instance the air core coil, does it attract or repell the north poles?
EDIT ok, I see the air core coil is meant to pickup inductive current only. But should it not be on the left side to force the ferrite core to go beyond the sticky point?
overunity7
Quote from: dieter on April 27, 2014, 01:16:48 AM
Look at the rotor and the coils, the coils must be placed exactly as showed in the photo, you must watch previously this video:
http://www.youtube.com/watch?v=bssBAb6EzM4
The white lever showed in the video has the same fuction as the receiver coil in this new system.
DreamThinkBuild
Hi Overunity7,
Here is a patent with similarity, at least in theory.
US 7602130 - Apparatus for self-generating a driving force to rotate a shaft without external power after initial activation
https://www.google.com/patents/US7602130
overunity7
Well, I know I said the v-gate dcs can works without external power after initial activation, but the device should be build with the perfect materials and with the perfect proportions and it is something tremendously hard to make, in order to have a v-gate dcs easily working you will need external power and a integration of the Bedini circuit, (it was not added in the picture).
