The Bessler Wheel, mystery solved.
Started by gurangax, April 24, 2014, 02:40:13 PM
Ok, you want to play, fine. I'll play.
How about making a little wager?
I'll bet you that you will not show any working device. Ever, but let's put a time limit on the bet, say, one month plus a few days. Call it June 1. If you haven't shown a real working Bessler-variant wheel by June 1, I win the bet.
Let's say, if I win, you make a one hundred dollar donation to your local no-kill animal shelter or neuter-spay program. If, on the other hand, you win.... then we all win, because you will have Saved the World from the Tyranny of Big Oil. And I'll make a hundred dollar donation (of my now worthless money)  to you or the charity of your choice.
:P
(Drawings and theoretical calculations DO NOT COUNT without a functioning prototype. You are claiming to have something that works... and I say you do not. So show your working device, not a drawing of it!)
gurangax
Quote from: TinselKoala on April 26, 2014, 08:43:57 AM
:P
Wager or not, I still will disclose it before your said time limit. Anyway I accept this wager.
regards
gurangax
Why do they fail? Its because they are looking it only on paper which is 2 dimensional. Everyone keeps repeating this error. Now open your mind and do it in 3 dimension. I have told you earlier the key lies on the z axis.
regards
gurangax
why does a windmill works? I guess it because of the larger particles that can be felt hitting the blade and causes movement. this concept is just the same with a water turbine.
gravity is everywhere and cannot be felt because we are already accustomed to our own weights. what it does is simply attract all masses to the source of gravity. it is something that I can not explain very well.
The closest thing to a gravity is a magnetic field. If there is a very large magnetic field the device will surely work by the same principle of attraction.
I wonder about pressure, for example at the very bottom of the sea where pressure are the same all over a body.
Well this is just something that come to my mind anyway.
regards.
Paul-R
Quote from: gurangax on April 26, 2014, 09:18:04 AM
they work like an aircraft's wing. suction due to Bernouille's Theorem.
