The Bessler Wheel, mystery solved.
Started by gurangax, April 24, 2014, 02:40:13 PM
PiCéd
With levers you gain weight but you lose v.
gurangax
Quote from: gurangax on April 26, 2014, 09:51:00 AM
Now I will say this.
It is not the weight that causes the machine to work. It is the levers! Without them your device simply doesnt work. Levers this is the secret of a perpetual machine.
regards
Bessler wheel is not really a perpetual motion wheel, it simply extract the energy from gravity to do work, so I can assure you there will be energy surplus. It gets the energy from gravity attraction the same way you get energy from a windmill! Simply said a perpetual motion machine doesn't exist!
-regards
gurangax
Quote from: PiCéd on April 26, 2014, 10:06:48 AM
Read everything I have told here
mscoffman
Quote from: gurangax on April 26, 2014, 09:36:12 AM
I have an idea which will work on pressure and it is not a turbine. It is based on the 2 stage lever i was talking about earlier. The more I think about it I found that it will work with any force which is 1 sided.
regards
gurangax,
I think that you and Mr. Rossi should be careful not to threaten to eat your customer's lunch for him. To focus on the simplest application
of a principle or you will come to not ever focus on any of them. The way patents are written should advise you of this.
I suspect that it's not MIBS that screw up inventors...it's the inventors behavior...themselves. Don't let valuable primary
ideas be held hostage to the vagaries of application secondary less valuable ones. Of course to do so would only be human,
but that's not something that we need right now.
:S:MarkSCoffman
PiCéd
Without a simple schema there reason to be skeptical.
