COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
x_name41
Quote from: hartiberlin on July 22, 2014, 07:20:45 PM
@x_name41Nice !
What is the output versus input power ratio in your device ?
Many thanks !
Regards, Stefan.
I have no idea, because i used sound card as a oscilloscope and i had no opportunity to calibrate and adjust the ratios, for the ratio between input and output power i can say that in the DC power supply i have 3,45V/0,54A.- without load, and with load have 3,68V/0,53A. Load is it incandescent bulb on a 24V/0,020A. I would like this device, to use it for laptop power supply :)
hartiberlin
I am still playing with the simulator.
I came up with this  output circuit
by also using there a switched cap which makes the output pulses bigger.
The switching pulses are inverted to the main switching pulses, so this second cap
is 180 degrees out of phase switched onto the load resistor.
Well, as thze second scopeshot from the left ( the white one) shows the
actual peak values of the input power, where the minus amplitude means
POSITIVE input power and the positive wave means NEGATIVE input power (power delivered back to the grid)
you see, that this circuit draws around 826 - 610 Watts= 216 Watts...
But these are only the peak values...so no real RMS measurements.
At the load resistor the peak values are 279 Watts, but surely the curves must be integrated
to see the real RMS output power. This is unfortunately not available in this simulator...
Well you can see, if you switch the output switching OFF with the switch at the top,
the amplitude at the load resistor falls to around 96 Watts Peak.
$ 1 4.9999999999999996E-6 3.3115451958692312 11 5.0 50
v 144 496 144 368 0 1 60.0 177.0 0.0 0.0 0.5
w 144 368 208 368 0
w 304 368 368 368 0
r 560 224 560 288 0 25.0
r 144 496 208 496 0 0.01
c 576 400 576 464 0 5.9999999999999995E-5 141.54046248279113
159 464 496 528 496 0 0.1 1.0E10
159 528 368 464 368 0 0.1 1.0E10
159 464 400 528 400 0 0.1 1.0E10
159 528 464 464 464 0 0.1 1.0E10
w 464 464 464 496 0
w 464 400 464 368 0
w 528 368 576 368 0
w 576 368 576 400 0
w 528 496 576 496 0
w 576 496 576 464 0
w 528 464 560 400 0
w 528 400 560 464 0
w 560 464 576 464 0
w 560 400 576 400 0
w 496 352 496 320 0
w 496 320 624 320 0
w 496 512 496 576 0
w 400 576 496 576 0
w 496 576 624 576 0
w 624 576 624 320 0
w 496 448 496 432 0
w 496 416 496 432 0
w 496 432 432 432 0
w 432 432 432 640 0
w 368 368 368 352 0
w 464 368 464 288 0
R 400 576 288 576 1 2 120.0 2.5 2.5 0.0 0.5
R 400 640 336 640 1 2 120.0 2.5 2.5 3.141592653589793 0.5
w 400 640 432 640 0
g 144 496 144 512 0
T 464 224 560 288 0 0.05 0.5 -4.826693570851079 1.0364586850695607 0.5
w 368 224 368 352 0
w 304 496 464 496 0
w 368 224 464 224 0
w 208 368 304 368 0
w 208 496 304 496 0
w 560 224 688 224 0
w 560 288 672 288 0
w 672 288 752 288 0
w 800 496 960 496 0
w 896 640 928 640 0
R 896 640 832 640 1 2 120.0 2.5 2.5 0.0 0.5
R 896 576 784 576 1 2 120.0 2.5 2.5 3.141592653589793 0.5
w 960 368 960 288 0
w 928 432 928 640 0
w 992 432 928 432 0
w 992 416 992 432 0
w 992 448 992 432 0
w 1120 576 1120 320 0
w 992 576 1120 576 0
w 896 576 992 576 0
w 992 512 992 576 0
w 992 320 1120 320 0
w 992 352 992 320 0
w 1056 400 1072 400 0
w 1056 464 1072 464 0
w 1024 400 1056 464 0
w 1024 464 1056 400 0
w 1072 496 1072 464 0
w 1024 496 1072 496 0
w 1072 368 1072 400 0
w 1024 368 1072 368 0
w 960 400 960 368 0
w 960 464 960 496 0
159 1024 464 960 464 0 0.1 1.0E10
159 960 400 1024 400 0 0.1 1.0E10
159 1024 368 960 368 0 0.1 1.0E10
159 960 496 1024 496 0 0.1 1.0E10
c 1072 400 1072 464 0 3.9999999999999996E-5 6.982940362918084
w 960 288 960 224 0
w 800 496 768 496 0
w 768 496 768 288 0
w 768 288 752 288 0
w 688 224 768 224 0
s 768 224 960 224 0 0 false
o 0 16 0 291 261.87124863169134 20.94969989053531 0 -1
o 0 16 1 291 2094.9699890535308 9.765625000000001E-155 1 -1
o 5 16 0 34 320.0 3.2 2 -1
o 5 16 0 289 114.55561567389984 18.32889850782398 3 -1
o 3 16 1 35 489.88833106573423 9.765625000000001E-205 4 -1
Marshallin
Quote from: x_name41 on July 22, 2014, 08:13:47 PM
Maybe you can try to self-loop your device. Instead of lightbulb use brige rectifier and 400V cap, and bring all power back. It will work or not :D.
All this mesurment with light bulbs and standard multi-meter are inconclusive anyway.
popolibero
Guys, I would stick to the basics and go from there to see if it works before trying new stuff, or it will be endless...  Even just sticking to the basics we need to make assumptions. For instance, I started my thinking about the serps starting from a basic tank circuit. Visualize the cap charging and discharging with regards to voltage and current. As soon as you start inserting a load in series with the cap and coil (the secondary of our transformer) the phase shifts and the source starts to see the tank as a load. The higher the resistance the worse it gets. BUT if we force switch the tank to stay in the 90-180-270-360 phase switching in theory it should work right? If we now start inserting a load (resistance) it takes more time to charge/discharge the cap, but we need to charge and fully discharge it before each reversal. So we know that the higher the load resistance, the smaller our cap value and vice versa. Keep in mind that a non switched tank circuit works well with open core coils. Closed cores, be it toroidal or E type is terrible, so here me have to make assumptions. Do they use standard ones or modified cores..?
Jim's early demonstration shows he was using the full duty cycle (25%) per quarter.  In the last one they only use about 13-14% of the duty cycle. And the waves look different. When I went to parallel/series switching the current waves actually looked the same as the ones on the plastic box scope shots of the latest demo, except that the discharge current was about half.
We have to analyse and test what we know and work from there.
regards,
Mario
btw, what has the bitoroid stuff to do in this thread?
Let me see if I understand. Your load is 24V bulb drawing 20 milliAmps, for a power of about half a Watt.
You are supplying 3.68V at 0.53 Amp, or nearly two Watts. This isn't really very good efficiency.
Are you thinking you can just take the _difference_ in the supply power, loaded and unloaded, and claim that that is your input power lighting the bulb? No, you aren't allowed to do that and here is why:
Turn on your garden hose and direct it out into your yard. Measure the flow rate at the faucet. This is your "unloaded" flow rate. Now, without changing anything, bring a bucket over and let the hose play half into the bucket and half into the yard. The bucket, your load, is filling up, right? Measure the flow rate at the faucet. Is it different than before? You are being charged for this flow rate, not just what hits the bucket.
