COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
Quote from: x_name41 on July 31, 2014, 11:58:48 AM
see now in the patent clearly states: Reactive power input =33,5VA, Active power out =25,3W, power consumption from grid =1,16W, Is not that this proof?
Of course it is not proof. Show me Thane Heins's electric bills for the past six months. If they are zero, or a negative number... That would be proof. Of something....
:P
Or you can tell us the story of his laboratory at the University in Canada. Why is he no longer working there?
x_name41
Quote from: TinselKoala on July 31, 2014, 06:51:19 PM
:P
I already said: May not to please him of such like you!, because whatever i show you, you again will not be you pleased and happy
Farmhand
That is not a patent, that is a "Patent Application", anyone can apply for a patent for anything even if it doesn't work.
It's a favorite ploy of scammers to make a patent "application" so as to try to give their device legitimacy in order
to get investment from not so savvy investors.
Basically the patent application is not worth the paper it's written on. It shows no proof, it's just another claim made by Mr Heins.
x_name41
so, you are already two trolls! It was a test which issue you, and how much yet there is such as you?
you deny the obvious, in this way you you are to the detriment on this board because you indicate symptoms of the serious mental health problem, and need to you are being
Farmhand
In order to see for sure if Thanes BiTT is OU you just need to try to run it from a pure sine wave inverter powered from a 12 volt
battery and monitor the battery output as well as the AC meters and such while the experiments are under way. Then tally up the
energy used and the energy output as intended output in the load resistor, the load resistor should have it's temperature
monitored as well. I'd say his measurement protocol and execution are not accurate.
Thanes BiTT is not a generator, it uses the grid as a power supply and he disregards all costs involved in providing his input as well.
Build one run it from a battery and make free power why don't you ?
Rather than abuse and accuse. Why not do something ?
