COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
x_name41
Quote from: Farmhand on August 01, 2014, 09:21:02 PM
In order to see for sure if Thanes BiTT is OU you just need to try to run it from a pure sine wave inverter powered from a 12 volt
battery and monitor the battery output as well as the AC meters and such while the experiments are under way. Then tally up the
energy used and the energy output as intended output in the load resistor, the load resistor should have it's temperature
monitored as well. I'd say his measurement protocol and execution are not accurate.
Thanes BiTT is not a generator, it uses the grid as a power supply and he disregards all costs involved in providing his input as well.
Build one run it from a battery and make free power why don't you ?
Rather than abuse and accuse. Why not do something ?
and sample of the tar, don't you want?
nelsonrochaa
Everything seems simple .... for those who have resources available, is more simple,I have no doubt.
Maybe you can provide a pure sine wave inverter to x_name41 to test.;) all tests you say !
What I mean by this is that it is easier said than practice without passing the abundance of resources.
We can not forget that most people do this as a hobby and not as a full time job (I wish).
The effort of the people should not be underestimated but rather used to improve the understanding of some phenomena.
This may not be an activity where only the elite few can recreate these tests because have resources.
My resources are low and try to adapt materials that would normally go to waste I think it is also a way to involve more people with fewer resources and give them the opportunity to engage in this area.
Never forget that almost all of these phenomena have been discovered and recreated without the use of present available technology .
I also need a pure sine wave inverter to test some things I have in mind, but it is not easy to get $ to buy one.
I think people like  x_name41  not spending resources and time to fool anyone; what is the idea?
I could have the same opinion of those who only live to criticize without ever recreated some of these tests to verify its veracity.
Farmhand
Well I don't want anything really.
But as for the inverter a cheap 150 Watt inverter can be got for quite cheap, you could then apply a filter to the output to
get a sine wave from it. The wrong load would likely fry it or shut it down or blow a fuse.
The suggestion was mainly to point out  that Thane does not even provide his own input power he relies on the grid.
Why is that you may ask.
x_name41
Quote from: Farmhand on August 02, 2014, 09:40:18 AM
Farmhand calmly I can tell you that you are idiot, my conscience is clear!
nelsonrochaa
Hello Farmhand, and how I'll do a convenient filter to get a sine wave  without oscilloscope?
And how will I buy an inverter with a measly salary € 410 for the whole month to pay family home etc?
Look it's not that simple ... But thanks for the tip
[/quote]
