COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
Farmhand
Quote from: listener191 on August 16, 2014, 03:53:17 AM
Hi Farmhand,
Cheap energy meters see the peak of the projected current sine over the gap between charge and discharge pulses, hence for this waveform on my setup, the meter displays 34W, 93VA, 0.37PF so 59VAR, 68 deg.
Barry
Yes but don't you have a control wave form, with input and output powers while powering the load without the switching in place
but with the same applied voltage ? At least then we can see the effect of the switching. If we take switched and un switched
wave forms from the input and the output then we can determine the input and load power in both cases without meters.
I think that is a much more scientific way to go.
Impressive work with the circuit. Great work on producing the wave forms/replication.
popolibero
listener191
Quote from: Farmhand on August 16, 2014, 09:52:52 PM
Hi Farmhand,
When you say "no switching", if the charge/discharge switches are turned off, there is no circuit for current through the load?
Could you explain the configuration you would like me to try without  switching?
Re the switch circuit..appreciate your thanks!
Barry
Farmhand
Well I guess just power the load from the supply that feed the switching circuit power rails, like just bypass the switching circuit
altogether by powering the load from the AC source that is being switched now. But only if it's convenient if it's a lot of trouble
don't do it on my account. Just curious is all.
Farmhand:
I note that you are being bashed on the mirror thread by a few Ignorance Enforcers and you are holding your own very well.  Aaron was one that really beat you up.  I also note that after 10+ years, he still cannot string five sentences together about an electronic circuit that make sense.
It would be great if somebody actually made the power-in and power-out waveform measurements in a proper fashion like you have been stating.  One can only hope.
What makes this one extra distasteful is that I think you have to buy the DVD to "really" discuss the alleged system.
