COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
Farmhand
Listener, What about switching the bulbs from a parallel to a series configuration for the duration of the cap discharge as Stefan
suggested ? Or was it the other way around ?
gotoluc
Quote from: Farmhand on August 12, 2014, 11:44:39 AM
I would be very interested in seeing the scope results of a double capacitor Tank being charged in parallel then discharged (through load) in series would have. It would also be nice to test the opposite (series to parallel)
This makes the circuit much more complicated but I'm sure you're up to the task Farmhand ;)
Luc
listener191
Hi Farmhand,
That last scope shot was for parallel charge and series discharge caps.
As this will also simulate on Falstad, I have tried 3 caps in parallel and series discharge, with no improvement in discharge amplitude.
I have also tried simulating two inductors charging and discharging. The charge waveform is fine but the discharge waveform although initially a high voltage spike, hence high current, rapidly collapses, so the situation is similar to the parallel/series caps... less area under the discharge pulse  compared with the charge pulse.
To get the PF/phase shift that Babcock/Murray have achieved, i.e. equal areas under the pulse, something else is required.
Barry
popolibero
Quote from: Farmhand on August 12, 2014, 03:27:29 AM
Well, if as Mario said on the other forum the power is just borrowed and returned....
These are actually not my words but Murray's.
regards,
Mario
listener191
Attached Falstad capture. Switched identical loads so you can see the power in both directions.
26.12W charge
13.22 discharge
40W input from source
$ 1 5.0E-6 14.841315910257661 43 5.0 50
w 464 304 464 256 0
w 464 304 400 304 0
c 464 336 464 400 0 6.0E-6 -62.310406866095015
c 464 496 464 576 0 6.0E-6 -62.310406866095015
178 400 304 400 384 0 1 1.0E-9 1.000000082740371E-5 0.05 1000000.0 1.0E-9 1000000.0
178 576 416 576 496 0 1 1.0E-9 1.000000082740371E-5 0.05 1000000.0 1.0E-9 1000000.0
w 464 400 576 400 0
w 512 464 464 464 0
w 512 464 512 512 0
178 720 512 720 416 1 1 1.0E-9 -9.999999999999999E-6 0.05 1000000.0 1.0E-9 1000000.0
w 720 512 512 512 0
w 576 400 576 416 0
w 528 416 528 368 0
w 544 416 544 368 0
w 544 368 608 368 0
w 528 368 528 320 0
w 608 368 608 320 0
v 528 320 608 320 0 2 100.0 5.0 5.0 0.0 0.5
w 352 304 352 272 0
w 352 272 528 272 0
w 528 272 528 320 0
w 368 304 368 288 0
w 368 288 608 288 0
w 608 288 608 320 0
w 672 416 672 368 0
w 672 368 608 368 0
w 688 416 688 352 0
w 688 352 512 352 0
w 512 352 512 368 0
w 512 368 528 368 0
w 464 464 384 464 0
w 384 464 384 384 0
w 560 496 560 576 0
w 560 576 464 576 0
w 736 416 736 400 0
w 736 400 576 400 0
T 112 448 208 368 0 4.0 1.0 0.3013013529432025 -0.35694394279911656 0.999
w 208 176 208 288 0
w 208 448 208 576 0
r 112 448 48 448 0 0.01
w 48 368 112 368 0
v 48 368 48 448 0 1 50.0 155.0 0.0 0.0 0.5
w 208 576 464 576 0
w 208 288 208 368 0
w 1008 176 992 176 0
w 1008 256 1008 176 0
w 912 304 912 288 0
w 896 304 896 272 0
178 944 304 944 384 0 1 1.0E-9 1.099E-320 0.05 1000000.0 1.0E-9 1000000.0
w 1008 304 944 304 0
w 1008 304 1008 256 0
r 928 496 928 576 0 200.0
r 976 512 976 576 0 200.0
w 976 176 992 176 0
w 464 256 464 224 0
w 464 224 784 224 0
w 784 224 784 576 0
w 320 176 976 176 0
v 880 224 960 224 0 2 100.0 5.0 5.0 3.141592653589793 0.5
w 464 304 464 336 0
w 464 464 464 496 0
w 928 416 928 384 0
w 960 384 976 384 0
w 784 576 928 576 0
w 928 576 976 576 0
w 320 176 208 176 0
w 928 416 928 496 0
w 880 224 880 272 0
w 880 272 896 272 0
w 912 288 960 288 0
w 960 288 960 224 0
w 976 384 976 512 0
o 41 64 1 291 160.0 9.765625E-5 0 -1
o 51 64 1 35 18.707220957835556 9.765625E-55 1 -1
o 52 64 1 35 40.0 2.44140625E-5 2 -1
