COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
Quote from: TinselKoala on July 09, 2014, 11:00:29 PM
.... based on the device and measurements I showed in the QEG thread.
Where exactly ?
Please post exact URL to the posting. Sorry as I am very busy I can´t read all threads...
Quote from: Farmhand on July 10, 2014, 02:20:09 AM
.... and if that reactive power is not returned to the grid ...
Indeed it is returned. that is why it is only using 1.1 real active Watts in this case
and the reactive power oscillates back and forth between grid and your device.
And in the device it is used as Real Active power...!
But the grid sees it coming back as reactive power, so you don´t need
mechanical power in the generator to produce it, it just oscillates back and forth..
So you don´t need to burn oil or cole to produce it...
Farmhand
Well for energy to be transferred to the load then power must be consumed, if the power is returned to the grid then it is not
consumed and so it did no work that is reactive power, if the power does work then it is consumed and therefore cannot return to
the supply.
There must be a mistake or a deception at play. We cannot use power then return it to the supply, it's as simple as that. Once we
use it as real power then it is gone out of the system. If it does not leave the system then it isn't dissipated and so it is not output.
I treat those guys like politicians, unless there is hard proof of what they say you can bet it's all lies. There must be a play on words
which means not what it says.
Of course time will tell, but that is what they all prey on, it goes on forever with never any real useful info or anything just a baited hook.
None of it makes any sense at all, there is no logic to it and absolutely no reason to believe anything that any associates of Aaron Murikami say.
I've said my piece so I won't argue any more. to put it simply Energy cannot be created and we can only dissipate energy from a
system once, as soon as any energy is dissipated as work it is no longer in the system. We cannot dissipate energy out of a
system as work then miraculously have it back again to dissipate once more.
forest
Farmhand
Are you sure that the electrical energy inside wires is converted into heat and light on bulbs ?
I know you can imagine a resonant system wih a perfect bulb which do not change resistance during time...how is that powered by less input power .... got the idea ?
Farmhand
And as for Eric Dollard, In my opinion he is doing his reputation irreparable damage by associating with them and contradicting himself.
In a recent posting he claims that a distribution transformer can be used to create a VLF Tesla system and compares pole
transformers to Tesla coils, saying that a 1/4 wave resonant distribution transformer at resonance will act like a Tesla transformer.
And after all his postings about how the Tesla transformer is special and all, then he comes out and says a pole transformer will do
the same at low frequency. Go figure. A Tesla coil is not required for ground wave transmissions. It can be done with about any transformer.
Nothing special about the Tesla transformer as far as energy transmission goes. Nada. Eric made himself obsolete with that posting.
He is full of contradictions.
