COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
SeaMonkey you are wrong !
You can just use a 120 Volts AC producing 60 Hz sine wave oscillator battery driven or via a supercap,
that outputs
1 Watts of output power ( and needs maybe only 2 Watts itsself)  into this SERPS Babcock Murray circuit and instead of the
lamps you use a feedback circuit back to the oscillator and get this thing thus to selfrun.
At COP=50 this should be no real problem...
Regards, Stefan.
SeaMonkey
I would love to be wrong on this.  We shall see.
Is the COP of the device Real or is it Trickery?
I cannot imagine how it would power itself, even
after being started from the grid...
havuhung
Hi All,
The issue here really is hard to judge! . . I'm really looking forward to a sufficiently detailed picture of this device or is an exact circuit schematic and it really is!
ARMCORTEX
I made many crazy circuits in my life. I was more into the mechanical OU because I have a sure bet design right now, and I like big HP
I really shouldnt be distracted by parallel projects, But there is no beating raw cheapness of electronics.
From oscillators to logic to microcontroller to switch setups, I am up for a try.
Brg forward more info so that I see exactly what I must do, a nice prezi with diagrams and colors.
SchubertReijiMaigo
Quote from: hartiberlin on July 11, 2014, 11:06:36 PM
In the new Babcock-Murray Serps circuit presented at the Bedini 2014 conference
the actual line input AC voltage is regular 60 Hz sine wave.
They did not publish this in the first left scopeshot, cause that would have given the
timing away...but the comparison of both scopeshots gives it away anyway, so that is why I wrote
it was an eye opener...
I think I know now, how it is working.
I pondered all day long now about it.
Imagine a sine 60 Hz wave input.
One cycle is 0 to 360 degrees.
It seems they just charge 2 caps in parallel via the lamps load from 30 to 90 degrees from the line voltage.
After this they electronically disconnect the 2 caps and put them in series
and at around 100 degrees , they discharge the 2 series caps back to the line voltage  versus the lamps again to about 160 degrees.
This way they have double the sine peak voltage to be able to discharge the 2 series caps and drive negative current back to the grid
through the lamps !
Then the same thing happens for the negative half wave of the sine wave.
At around 210 degrees the 2 caps are again switched in Parallel into the line voltage via the lamps in series and charged
until around 270 degrees up to the peak voltage of the 60 Hz sine wave.
Then at 280 degrees, the 2 caps are put in series and again discharged via the lamps back to the grid until around 340 degrees.
So again energy is returned to grid via the lamps as the load.
It is basically a very easy circuit, but you have to have the right timing and the right load impedance (lamp resistance in Ohm in this case),
so that the areas in the input power MATH trace above and
below the ground line are about equal.
So you minimize the real active input power and try to get the aparent input power
the same as the reactive input power. If you get it right, you will only have reactive input power
and almost no Real active input power. Thus a COP of about 50 as they have shown at the conference can be real !
Great circuit !
Regards, Stefan.
Problem I've never heard that putting cap to series/parallel can give OU, the energy state still the same because capacitance reduce when put in series...
That being said, Hector Perez (the guy with his rotoverter) claimed in special resonant configuration, that you can extract real power from the reactive one, playing with phase (usually three phase power) is the key.
According to him he reversed current in the battery through the inverter ("reverse" power factor correction).
The load and the inductor act "negative" but a lot of impedance matching is necessary.
In the "combine" PDF you can read that is when R is at current node it's powered by "radiant energy" full light with 1/10 of the input voltage...
This theory is worth what it worth...
Anyway I would like to see a schematic of that circuit before making my definitive opinion.
