Toroid-magnet-generator
Started by wizkycho, August 30, 2006, 06:26:18 PM
wizkycho
@broli
I may not agree with such certanty that Lentz is bypassed completely and that easily,( although with experimenting and using thicker coil in diameter (not wire) some unexpected
values may appear), and here is why: although current will be small number of turns is big so lentz force will probably end up proportionally to created EMF that moves magnet and everything ends up under 100%.
But in these setups with high turn ratio (type without sparks) it is possible to expect at certain rpm of magnet that lentz counter force or emf delays enough (another 180 deg) to form resonant product of waves. so this central core with moving magnet acts somewhat like laser's ruby - but this time without great initial losses in transfer energy (like lasers have). for this right frequency of input must be found and wait for some time till rotating magnet respond with sufficient and compatible resonant speed and observe
resonance mutiplication gain in power of 10 and more times then input - allso could be expected that if load's R (Z) changes device will slip out of resonance and energy amplification.
keeping it in mind -
maybe could be used to educate underunitors in their dark stinky underworld that resonance is easy example of apparent, actuall and messurable energy amplification and gaining large ammounts of free energy, yes yes underunitors this is not near as just accumulator efect. this is constant low ENERGY input and constantly multiplied ENERGY at output well and many times over 100% and that is completely usable on any todays constant R loads. don't say proffesors forgot to tell you !
giving it another tought, this is "M"EG but with moveable magnet and really looks like this "small" change can result in lowering lentz effect
this is type of idea that must be remembered and tried cause is very probable to be OU. You just might have solved MEGs inconsistency in replication and You done it with finess.
well done, indeed
Wiz
wizkycho you are way ahead of me there. I was speaking of a simple idea I have been thinking about that could be applied to your design.
Take a look at this...
http://www.energeticforum.com/renewable-energy/3967-dc-motor-generator-talk-obvious-gain.html
