tesla zpr generator cosmic energy
Started by tturner, May 26, 2014, 12:47:38 PM
Farmhand
Quote from: tturner on May 30, 2014, 04:58:37 PM
im just f****** sick of this energy war can someone help me get into the right.direction hopefully we can build something that works
The search goes on, if anyone had anything that worked it would be getting replicated and spread like wildfire.
People get ahead of themselves though. If someone was to drop off a 15 kW free energy machine to your house for free, what would you do with it ? Just wire it up to your house yourself ? Who will fix it when it breaks down ?
Any free energy device will need to be safe or it will be use at own risk and if it causes the death or injury of another then the owner operator is liable. People go to jail for negligence that causes harm to others.
And unless said device is safety certified in the country of intended installation no one will install it for you unless they are mentally deficient or leave no way to be tracked down. No certified electrician would risk jail for a few days work.
In my opinion it won't be long before grid supplied electrical power is so expensive and privatized that we will need to pre-pay for electricity before we use it.
Best to be getting ready to be able to live at least temporarily without grid power. It can be done already with existing free energy devices. I'm set, there is just me I don't really need the grid to survive but it is cheap and very handy to have.
Don't use other peoples power if you don't want to pay. That may involve a lot of learning for some to do.
Work out how you can run a refrigerator and a light without the grid and your set. A lot of people get grid tied solar systems but they don't buy a bank of batteries an inverter and a big charger so they can run stuff when the grid goes down then charge the batteries with free energy from their solar panels via the wall socked when the grid comes back on line.
Make alcohol and distill it to 80% to use for heating fuel for cooking ect. and store it well.
Best thing I can suggest as far as new and novel free energy goes is buy or obtain a large deep cycle battery then try to work out how to charge it for free, without connecting to the grid or harnessing electro-smog. It's a good idea to have a capable charger or learn how to build one, so the battery doesn't stay discharged too long if a certain method doesn't work.
People have a lot of theories including myself but if they don't work they don't work.
Truth is no one has shown any credible devices or evidence for such like solid theories that can produce a substantial power output for free. Not that I am aware of.
tturner
Liberty
Quote from: Farmhand on May 31, 2014, 02:26:50 PM
Another idea is to use grid tie inverters without the grid (by making sure the grid is completely disconnected).  To do this, a substitute grid will be needed consisting of a sine-wave ups that can be cold started off of it's battery.  The output of the sine-wave ups will supply the enable to turn on the grid tie inverters that are solar powered.  Since grid tie inverters normally use the load of the grid as a voltage regulator, voltage stabilizers (buck and boost) will help to regulate the voltage output to the load.
The ups sine-wave inverter will need a sine-wave input to restore power to the ups, so the ups does not continue to run off of battery.  A small sine-wave inverter that is powered from a solar panel or a battery that is powered from a solar charger, could supply a sine-wave input for the ups.  This set-up would not require a battery bank, but would only work during strong sunshine days.  A small generator that provides sine-wave output might also be used as the substitute grid.  This idea is untested to run a home, but I have successfully tested to see if a ups will enable a grid tie inverter.
Anybody else tried this before?
Liberty
thx1138
The big secret about free energy is that all energy is free. It was created at the Big Bang or however the universe was created if you don't subscribe to that theory, which I don't. You can't add to it and you can't destroy it. All you can do is change what is already there. I think it was Carl Sagan who said, "To make an apple you first need to create a universe." Ditto for energy.
So the real question is how much do you want to pay for your free energy. You could build your own solar panels but regardless of how you do it you still need raw materials. Or you could buy some land and drill a gas or oil well and convert everything including cars to LPG but then you need a compressor, etc. You see where that's going.
It's not the energy that is the problem. It is everywhere. In the ground and the atmosphere and outer space. In the atoms that make up those things and the ions in the atmosphere and even in the plasma in outer space. There is no such thing as a "vacuum". There is nowhere in the universe that is empty. There is energy in the earth's magnetic field and that of the sun and all the stars in the universe and even, they recently discovered, the black holes have magnetic fields.
The problem is harnessing the energy. The best fuelless energy is gravity because it is, to a large degree, constant but you need a river or lake to harness it. Gravity is free. The water cycle of the planet that carries water to heights and releases it to flow down streams and rivers is free. The dam and equipment to generate electricity and transmit it, wirelessly or otherwise, is not.
And even free energy won't solve the war problem. There were wars long before electricity or petrochemicals were harnessed. Bigger sials to sail the war ships faster. Coal to power war ships that wouldn't have to depend on the wind and move armies on trains to where they were needed. Petrochemicals (diesel and gasoline) packed more energy into smaller size and weight to make war machines more mobile. Interestingly war is usually behind all energy development - better power sources to power more devastating war machines. Tesla thought war was stupid and a waste of man's efforts also.
Unfortunately, it's the nature of the beast. I saw someone say WAR is an acronym for We Are Right. So if you can change human nature you might stop war. Then again you may not be able to change it that much. Wars aren't being fought over energy today. They are fought over ideology and physical and human resources. Read Sun Tzu's "The Art of War".
thx1138
Quote from: tturner on May 30, 2014, 10:33:29 PM
whats going on with the blue spike phenominom that tesla experimented with
It's known today as corona discharge and is what makes laser printers work.
