Akula eternal lantern 4
Started by MenofFather, June 01, 2014, 01:15:57 PM
Void
Quote from: Hoppy on March 10, 2015, 11:07:23 AM
For educational purposes: ...
Hi Hoppy, Aside from the fact that video has no relevance to this thread whatsoever,
that site that you link is plastered with x rated advertisements. Everything ok today mate? ;)
Akula's circuit is claimed to be self running, so measurement error or miscalculations should not be a factor with his circuit.
It either works as claimed or it doesn't. :)
All the best...
Hoppy
Quote from: Void on March 10, 2015, 02:04:24 PM
All the best...
Oh, I think it does! Measurements are not a factor that we can judge the performance of his device from because there are none supplied.  :( However, given that its almost certainly has a conventional power supply, I agree that measurement errors need not be a factor with this circuit. Now, we really must stop going in circles.
X rated ads  :o You were only supposed to look at the educational video.  ;)
synchro1
@MarkE,
Dr. Stiffler has one end of his solenoid coil connected to an "Earth Ground". The subtle perturbations from the "Earth Ground" are the sole source of the self oscillation of the coil, determining it's "Spatial Resonant Frequency". Earth's magnetic field flux is not stationary, but oscillatory.
"We're interested in the time rate of change of this flux, and let's say we have a circle with a diameter of 1 meter. The rate of change of the flux is thus (1 nanotesla/second)*(3.14 meters^2). Which is 3.14×10^-9 volts. Three one-billionths of a volt per square meter of flux-collecting Surface".
The coil oscillation is driven by the "Earth's magnetic field". The orientation of the coil axis in relation to the field effects the resonating frequency. Dr. Stiffler points out in his videos that even so much as a tiny piece of metal in adjacency to the coil is enough to influence the "Earth Ground" oscillating frequency. Why do you have trouble understanding that the coil simply acts as a magnetometer when attached to an "Earth Ground" and the sensitive measuring instruments?
The other important feature is that the coil and partners "Light LED bulbs" with no hidden batteries!
MarkE
Quote from: synchro1 on March 10, 2015, 03:57:24 PM
@MarkE,
And just where do you think either video established that claim?
Where is that quote coming from?  The B on the earth's surface is only 25-50nT.  1nT/s variation would amount to a 2% - 4% /s variation.  That is a large amount that would easily be visible on an ordinary compass.
That is something that you claim was evidenced in the videos but you have failed to point to where they supposedly do that.  The videos do not change the orientation of the coil.
QuoteDr. Stiffler points out in his videos that even so much as a tiny piece of metal in adjacency to the coil is enough to influence the "Earth Ground" oscillating frequency.
Placing metal in proximity to a coil changes the local capacitance and therefore impacts the simple lumped circuit model.  No "earth ground oscillating frequency" explanation is required.
QuoteWhy do you have trouble understanding that the coil simply acts as a magnetometer when attached to an "Earth Ground" and the sensitive measuring instruments?
No evidence has been presented of such a behavior.
A narrow band radio receiver connected to an antenna is supposed to deliver power to a load.  Why do you think that is exceptional?
synchro1
@MarkE,
Quote from you:
"A narrow band radio receiver connected to an antenna is supposed to deliver power to a load.  Why do you think that is exceptional"?
Here's a quote from Dr. Stiffler:
"Using just self resonance in three properly chosen and spaced coils coupled to earth will allow a condition where LED(s) can be driven".
                      "Self Resonance Coupled to Earth" is not "Radio Waves" MarkE! Now stop causing trouble!
Here's a video of Dr. Stiffler powering 8 white LEDS with nothing but an "Earth Ground", running inside a Faraday Shield:
https://www.youtube.com/watch?v=UAZ-eb6EDiA
We can see "Akula's Eternal Lantern 4 Unit" illuminating 8 blue LEDS as well on the Home Page right now with no input, so what's the big deal?
