Akula eternal lantern 4
Started by MenofFather, June 01, 2014, 01:15:57 PM
AlienGrey
Quote from: d3x0r on September 30, 2017, 11:09:11 AM
Ruslan replication
https://www.youtube.com/watch?v=kRVEE_9uTc0
Schematic on matrix-RU
Hi has any one actuly built this ? I ask this as the chip it a 74hc14 it's a 5 volt device and it goes bang at 5.5 volts and then eathere gets hot of fuses completely, so at 9v or 12v input it's any ones guess !
Hope this helps
AG
PS how many threads on this device have you got going ??
If you want free energy have you ever seen Faraday's homo polar genoratorhttp://www.juliantrubin.com/bigten/electric_motor_generator.html
It has a rotary magnet rotating one way and a copper plate rotating the other way you get a very low voltage but huge ampage out or it, look it up.
d3x0r
Quote from: AlienGrey on October 04, 2017, 09:14:27 AM
Hope this helps
AG
Ruslan did mention that he added a 5V regulator...
.. and since the scope shots seemed to show it working at every cycle after the field charged up, seemed that a high Q transistor could suffice. (hence the other thread that's more about converting to a joule thief type driver)
AlienGrey
Have you tried a HEF OR CD 40106 same sort of hex Schmitt trigger driver but get the B version it will work up to and over the 12 volt but might be unstable as fare as frequency stability is concerned at different voltages.
AG
