Light reactor theory and experiment.
Started by TommeyLReed, June 04, 2014, 05:02:14 PM
TommeyLReed
This is my theory of using pulse light luminous in a close sphere or  box.
If I pulse light like BEMF, but using luminous of light, could there be enough energy collected to close loop the system?
Like a flash tube, or led's that is power by a charge pump circuit.
As the small amount of energy is being used to charge up the capacitor, and being released to super luminous light wave is produced.
This luminous is collected in the solar panels to convert it back in to electrical charge.
https://www.youtube.com/watch?v=OYi4gEuy8Ug
TommeyLReed
This is a basic test to see if it could work, I believe it could collect light waves to recharge capacitors.
https://www.youtube.com/watch?v=gg_a-pOBD1Q
About this theory andspecially the real physical difference between "candela" and "lux/lumen" and the possibility to use this as a "light-box-generator" some info are delivered in the espacenet- archive !
Look f.e. for : Baquero Menendez (ESP)
                      Paul-Heinrich Marzahn
                      ..... Koehler ,Hans-Dieter Goeres et cet.
Sincerely
              OCWL
TommeyLReed
So what are you saying?
Is there other research on the net that has more data about this theory?
Do you have a link?
Tom
This is the global comercial knowledge net-archive,european section :
  www.epo.org and www.espacenet.com with entry to more than 80.000.000 documentations
        included automatic translation machine
                                                              "light box" related :
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=8&ND=3&adjacent=true&locale=en_EP&FT=D&date=20120322&CC=DE&NR=102010035706A1&KC=A1
http://worldwide.espacenet.com/searchResults?compact=false&ST=advanced&locale=en_EP&DB=EPODOC&PA=heinrich+marzahn
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=17&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20100615&CC=ES&NR=2341161A1&KC=A1
TIP/Advice  : go also to refered "cited / Citing documents"
Sincerely
              OCWL
