Ermola Andrei
Started by d3x0r, July 03, 2014, 07:49:14 PM
rstergar
Still no progress on replicating ermola gear...
Now I simplified this gear if someone can help me?
Need mechanism which will push blue gear from green circle only on outer half where orange dot is...
Watch simulation when I add spring you can see it is possible... but when it get on inner side of the blue gear I get reverse rotation...
https://youtu.be/NHcStpmHRVI
If someone have idea how to do it please share it... I believe we can do it together ;)
Thank you
Low-Q
Quote from: rstergar on April 16, 2018, 11:50:04 AM
Thank you
One question: Will a spring add energy into the system? You stretch it, release it. No magic happens.
Vidar
rstergar
After some time I get new idea about this motor...
https://youtu.be/0NGstpB5NzI
In practice, the yellow circle should be pushed to try rotate it which will then rotate silver gear and silver gear will push red gear to rotate around own axis and red gear will push on fixed green gear and then blue circle will rotate around own axis because red gear is attached to blue circle with bearings... my theory :) what do you think?
because silver and fixed green gear have the same number of teeths the yellow circle doesnt rotate...
i will try to build this model and test it...
you can try algodoo file to simulate it
thank you
rstergar
