A Gryroscopic Form of Overbalanced Wheel - Motor then OU
Started by mscoffman, July 06, 2014, 03:15:01 PM
ARMCORTEX
I said
To use it like this cancels out other advantages that a flywheel has, its a effective way of transporting mass for low energy cost, it is a source of acceleration as well, alongside its teammates, the central drive and the one way bearing, with these a  system can be created.
I have asked this specific question to physics forums, if moving the flywheel on same axis in a ''bowling ball throw'' action, but varying radius gains any advantage over non spinning weight, I got no answer yet.
Of course you could not understand what I meant since this is this exact and only solution, I will do something I shouldnt and release my design, it is in fact a reconfigured and re-engineered Dimitriev wheel. This is my main build, but sometimes I seem to get parallel ideas and get distracted, I should really be hunting the scrapyards and getting quotes.
But its not really the build, I managed to get things to work with middle connecting scheme, to reduce bearings to 4 and less pulleys, and have no secondary clearing wheels. Each bearing can handle 385 N/m of torque, they are 40$ each.
The Dimitriev wheel was imho, the easiest device on the internet, with respectable power output.
The thing is, that bearings dont last forever, so everything must be done to maximize the lifetime, you are not using fuel, you use bearings. So it is a flawed OU device, but I think it will be a smooth enough and slow enough process, so with good build conditions could last long enough to be better than current, way better.
