FREE ENERGY is here to stay
Started by that_prophet, July 08, 2014, 12:33:51 AM
MarkE
Quote from: one_christian_warrior on July 21, 2014, 03:31:30 PM
Ok, let's try looking at this from another angle
You are only putting enough DC electricity into this machine
To rotate your input pulley the once (minimal electricity)
Then through pulleys you are multiplying your rotations
You can use 10's to 100's of small pulleys
To rotate via pulley multiplication
Your 1cm pulleys turn 100 times each
Each one of these 100's of small pulleys
Has an AC generator on it to produce power
you must gain electricity from all of the AC generators
You cannot win:
Connect a pulley that is smaller by 1:N, then ideally that pulley rotates N times faster with 1/N torque.  Connect a pulley that is larger by N:1, then ideally that pulley has N times torque but rotates at 1/N rate.  In the ideal case you have transformed the power to a different speed without loss.  In reality, the bearings and coupling, such as a v-belt, chain, or toothed belt, all consume some of the power.
that_prophet
Quote from: TheCell on July 21, 2014, 11:33:36 AM
@that_prophet
if you have a working model:
publish your approximate location here, and allow people to visit you to make power measurements.
We cannot judge your device having no clue what's going on there.
Personally I cannot wipe out this all as nonsense . Many similar patents which cover this subject and many yt-videos. But I consider this as a time and money consuming setup, which if it fails , you probably have done better to put solar panels on your roof with a storage battery bank. This would work for sure.
yes, I have a working model
anyone could have  a working model
if they have an electric chair
with the settings turned up to max power + max speed
then if they go up hill at max speed
+ then back down hill at slow speed
they will gain the power to go further up the hill every time
they repeat their test of up + down hills
this was how I proved that it works to myself
I happen to be struggling with an electronic simulator at the moment,
trying to get a working model of this awesome free energy machine that God Shared
I believe that He wishes for this to be priority for me,
it is so simple, and easy to build,
could I ask for help getting a working model of this device out to the world,
http://free-energy.yolasite.com/
evil forces have put up barriers for me at every turn,,,,,,,,,,,,,,,,,
THIS WORKS, IT IS SO SIMPLE THAT IT HAS TO WORK
this device generates AC electricity by using mechanics of varying pulley sizes
to multiply rotations,
generated additional AC electricity by using multiple generators
Free Energy made simple = electricity multiplier using 100cm to 1cm pulleys
Don't believe in God or good + evil forces
Free Energy is so simple,,, that it MUST be hidden by evil forces.
It is simplicity at its best; you simple put the minimal power into a DC motor with a 100cm pulley connected to it, which only has to rotate the once. This large pulley is connected to a belt, strap, rope or even string in a pinch, which is also connected to another small one cm pulley, which rotates 100 times. So you put in the DC power to rotate your input motor only the once, and you get out of this system 100 cycles of AC power. You have just created your first free energy machine, that multiplied your electricity by 50 or 100. If anybody starts complaining about torque being a problem, just think about how smoothly bearings are nowadays, as well as how easily electric motors rotate. You could add ten of these small pulleys, without gaining any sufficient torque, giving you a 1000 power electricity multiplier.
A drawing and better description of how this works is at:
Please believe me + not all of the evil spirits
That are continuously saying, "this won't work"
Free energy is super simple
It has been staring us right in the face
Ever since we discovered how to make AC electricity
How is AC electricity made?
It is simply made by rotating wheels or pulleys
With these wheels connected to an AC motor
Which is easily created, by using a few coils of wires
And rotating them within the field of two opposing magnets
They will try to say what about torque
Torque is not a problem in the slightest,
As electric motors are the easiest to rotate
They have some of the smoothest running bearings
So you could add tens, maybe even hundreds
Of these AC motors, attached to mini pulleys of one cm circumference
On the same belt that you have a DC motor attached to as a drive motor
With a large 100 cm circumference pulley or even larger
So you only have to input enough electricity to rotate the drive motor one rotation
Then you get 100 cycles of AC electricity out of this system
For every mini pulley with an AC motor attached that you connect to the belt
that_prophet
Quote from: MarkE on July 21, 2014, 04:37:13 PM
You cannot win:
You are using multiple pulleys of miniature sizes to multiply rotations = AC power
FREE ENERGY HAS BEEN FOUND
   Yes, that is correct, Free Energy has been discovered, this electricity multiplier mechanism is dirt simple, and extremely easy to build, with spare parts even. Building this type of free energy device is not only easy, but is simple also, costing practically nothing to produce. This is mainly because you are able to build this contraption with spare parts, and very few parts at that.
   This device is extremely easy to build, with only a few moving parts, such as at least two pulleys, one large pulley, one or many small pulleys, and a belt, strap, rope or even string in a pinch, to connect the two pulleys together. There are only two more moving parts here, a DC drive motor, and at least one AC output motor/generator. I say at least one, as you could have many more, as the more generators you have, the greater the multiplication factor of your electricity multiplier unit. You can also increase your multiplication factor by increasing the circumference of your drive pulley, or decreasing the circumference of the output pulleys.
   The workings of this miraculous mechanism are pretty straightforward, and can be described by using a multiplication factor of rotations, by merely changing the size of pulleys. You put an extremely small amount of DC electricity into the drive motor, which has a 100cm circumference and only needs to do one single revolution. This drive pulley is connected to at least one one-centimetre circumference mini-pulley that acts as an output device, giving us 100 units of AC electricity, per every output pulley that is connected.
   I suppose that you might be able to see how this could start adding up, giving you 100 units of AC electricity for every output mini-pulley that you attach to the system. If you only added 10 of these mini-pulleys, then you would gain 1000 units of AC electricity, for every single input revolution of the DC motor that you put into this free energy device, otherwise known as GEM = Geometric Electricity Multiplier
·   THIS DOES WORK !!!
It just takes you to look past the lie,
That evil forces are whispering in your ear,
It is pure logic, that pulleys multiply rotations,
+ with AC electricity, revolutions equal AC power,
Satan hides this super simple free energy technology,
By immediately bringing up torque needed to rotate pulley,
Letting you forget AC motors are a breeze to rotate,
You could easily have 10 – 100 of them rotating at once,
And when the drag of load attacks, it is minimized by 1/10th to 1/100th,
Because of it getting divided up, so it lessens it so severely, that it works
Please believe me, and my Lord + Savior, Jesus Christ,,,
God So Much Wants to Give us this Little Miracle Device,
+ He only ask for your faith,,,
that_prophet
Quote from: tinman on July 08, 2014, 04:55:59 AM
So i clicked on the link to the web page(silly me),and seen the bible referenced as the book from where this idea came from.
Well thats me out.
YES,,, THAT'S WHAT EVERYBODY DOES
THEN THEY NEVER DO ANYTHING WITH IT
SATAN + HIS MINION ARE LAUGHING AT MANKIND
Let me describe a simple project:
You have a 100cm circumference pulley attached to a DC motor,
You connect a belt to this large pulley + 10 small 1cm circumference pulleys,
These mini-pulleys have AC motors/generators attached, (with no load at first)
Now you rotate the large pulley by hand,
This gives you a return of 10 X 100 = 1000 units of AC power
for every full rotation of the large drive pulley,
Now,,, try and tell me that this 1000 units of AC electricity,
Does not have enough voltage (electrical pressure)
To rotate your DC motor one time, (all voltage + only a spark of current)
that_prophet
@that_prophet
YES,,, THAT'S WHAT EVERYBODY THINKS
