Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
TheoriaApophasis
Quote from: gravityblock on July 27, 2014, 10:15:50 PM
ring magnet has an inverted field in the doughnut hole (inner diameter), and this is explained by the right hand rule and the reason for the opposite spins.
Actually it is explained by divinely simplex pressure mediation since there is no dielectric plane in the center, the "hole", which necessitates field reciprocation NOT ONLY from one "side" to the other, but from inner to inner
The field isnt inverted anywhere, its simplex pressure mediation, and there is no block in the middle for center reciprocation.
Congrats, you complicated what didnt require complication
Water is shooting out of a wall,   it falls down and rolls over the edge (to the other side)
cut a HOLE in the wall,  and it BOTH rolls over the edge (loose analogy) and THRU the hole to the other side.
Nothing is inverted, its only perceptually inverted  :o
There is no Bloch wall in a magnet.  That one is just a fallacy that seemingly will never die.
You disagree D3x?  Please go ahead and discuss what a Bloch wall is in a standard bar magnet.  You say the Bloch wall is at the half-way point of the magnet.  Okay, please elaborate.  What is the Bloch wall exactly in the bar magnet?  Just saying that "it's there" will not cut it.
Please tell us exactly what the Bloch wall is.
TheoriaApophasis
Quote from: MileHigh on July 27, 2014, 10:55:36 PM
Stuck your foot in your mouth with that one.  ROFL
"Bloch wall" is just a BS name given to what was (until NOW) not understood.   Its the dielectric inertial plane.
The "dielectric field (magnetism)" - Faraday  / Maxwell
Too bad your comments are just that.
You dont have clue 1 what you are talking about.
d3x0r
Ya probably a poor term to use http://en.wikipedia.org/wiki/Domain_wall_(magnetism)#Bloch_wall ... it's generally accepted(expressed?) it's the equilibrium line between north and south poles.  On magnetic viewing film it appears as a light region; but really magnetic viewing film is colloidal nickel(light) and colloidal iron(dark).  Where dark areas are is a field that is perpendicular to the film, where the light area is is a field that is horizontal to the film.  The point is the same white line is inside the ring as outside the perimeter of the magnet.  If the white line is called 'dielectric field' (and I chose bloch wall as a more conventional term for the same thing) then it also exists in the center.
TheoriaApophasis
Quote from: gravityblock on July 27, 2014, 10:23:44 PM
The inside diameter does not have the same pole as the outside diameter of a ring magnet!
Poppycock and twaddle.      Ring magnet is the SAME polarization throughout the ENTIRE magnet.
You are confusing magnetic polarization with apparent field polarity  DUE TO A HOLE BEING IN THE MIDDLE
Thats the mind screw of SPACE.
Thats the error of space that trips peoples minds.
ROFL!!!
Like most, you think there IS  CW and CCW,
spin anything, your wife, your cat, your dog, your pizza,   its moving IN ONE DIRECTION,      but apparently CW from one end, and CCW from the other end.
